Sponsored by:
Sponsored by:
fuse box
Old 03-03-2017, 09:25 PM
sst06vert
sst06vert's Avatar
Default fuse box
How do you open the fuse box inside the car by the kick panel on passenger side? Thanks
sst06vert is offline
Old 03-04-2017, 08:03 AM
Moderator
JimC's Avatar
Once you pull the cover off the kick panel you have to release a tab on the box cover itself. Can't remember which end it is on, front or back.
I always had to pull the full kick panel off though to release the tab on my 2006. Couldn't get enough leverage through the little access panel. To remove the entire panel pull up on the door sill first to remove it. Then pull the entire panel back. That will expose the entire fuse box.
JimC is offline
Old 04-24-2018, 08:35 AM
ItalianStud
ItalianStud's Avatar
Default Cover fuse box
Hi , I can't figure how to take the cover off the fuse box, did you have any luck taking your cover off. My is 09 and my radio quit on me after jumped start the car several weeks ago. Thanks.
ItalianStud is offline
