Sponsored by:
Sponsored by:
TECH: replacing the stock throttle body
Old 03-14-2008, 09:49 AM
  #51
rugedraw
rugedraw's Avatar
Default RE: TECH: replacing the stock throttle body
Very helpful thread. Im going on a mssion with my TB. I'm a make it work, though. I'll be sure to come back here and post my results.
rugedraw is offline
Old 09-06-2009, 02:54 PM
  #52
projectbrembo
projectbrembo's Avatar
I'm probably getting the ford racing gt500 throttle body. Expensive but maybe worth it after I put on headers.
projectbrembo is offline
Old 09-06-2009, 04:03 PM
  #53
Sleeper05
Sleeper05's Avatar
I gained 11rwhp with a TB swap. I've since gone back to the stock one because I'd rather walk a 400-mile road trip than drive a Mustang with an aftermarket throttle body. They are all crap when it comes to drivability, regardless of how much you try and tune them out.
I had a GMS twin62mm
Sleeper05 is offline
Old 09-06-2009, 04:07 PM
  #54
my77stang
my77stang's Avatar
for you guys who are contemplating a larger TB a cheaper route may be to pick up a unit from a 6.8 V10 (60mm i believe) and a cheap billet spacer off ebay. I think I was in mine a total of around 100-125 bucks.
To get it to fit I had to do a little dremel tool work on the spacer and on the bolt holes in the new TB, and use a "fernco" piece of rubber to adapt the larger inlet mounting flange to my CAI but in the end it worked perfectly and did not require a retune. I *think* the idle is slightly higher, maybe 50-100 rpm over stock which hasn't been a problem at all with my automatic and honestly now that it's been on for awhile I haven't really noticed it.
Did I pick up an increase? Who knows, I installed my CAI and tune at the same time - but I doubt it hurt me and it's just 1 more mod done to the car
btw this is for a GT not the sixxers obviously
my77stang is offline
Old 03-28-2010, 02:28 PM
  #55
sidewinder_83
sidewinder_83's Avatar
Wink bbk 62 mm throttle body
Hey guys i just bought a 62mm tb from bbk ive read all the post on this tb issues but im going to try to install it next weekend ill let you know how it goes...thanks for the heads up
sidewinder_83 is offline
djbigskrilla
09-20-2022 01:04 AM
mirandaandjimmy
11-16-2015 08:51 AM
01blackgtconv
08-14-2015 04:50 PM
stanngg
08-12-2015 03:43 PM
01blackgtconv
08-10-2015 01:25 PM
Quick Reply: TECH: replacing the stock throttle body
