Cervinis DuckTail
RE: Cervinis DuckTail
jollygreen; I just went down stairs and took the factory wing off took some pics with the Cervini's dock tail in place as you can see from the pics it does cover the factory holes. Also there is a screw that will go through one of the holes and attach to the dock tail when it's installed. I'am off work for the next twoweeks and I hope to have mine completed before I go back to work.
UP-DATE ON CERVINI'S KIT INSTALLATION: Kit came in Friday afternoon, had to do the preChristmas thing all day and night Saturday. Got started jacking and installing the springs Sunday at around 12:00 noon (had to wait for the garage to warm up) with the car on jack stands and me beeing in the upper fifty's it takes me a little longer getting under the car and back out again, anyway completed the springs around 4:00pm.
Pulled the old exchaust system off from the "H" pipe back and installed the new system with the side skirts this took me till about 12:00 AM.
Started Monday at 12:00 noon pulled the old front bumber off and had to removed the parking light rear retainers and install them on the new front bumber. installed the lower grill with the fog light buckets (just to make sure everthing fits & it doesn't) the back of the lower grill where the buckets go there are two C type brackets for each bucket welded so you can mount the buckets; but they are welded two far out for the screws to go through the holes and mount the buckets. Cervini's said to install the screws at an angle. I'll worry about correcting that when it's back from paint.
Installed the uppr grill and the PIAA lights and all the wiring and switch, you can set them up to come on when you turn on your bright lights or off with the brights on with the switch that comes with the system. Or stright wire the switch so you can turn them on anytime.completed the installation of the front bumber, installed the hood, wheels and tires lowered the car Time 12:00 midnight Monday.
Wednesday took car over to Tim Stewarts Ford for the paint work and the strips to be painted on. Here are some pics of the kit and after it was on the ground ready for the drive to TSF. SEE NEXT MESSAGE FOR MORE PICS:
andyman; they will only go on one way, and they are marked L&R on the bottom! Beleave me I tried ever way possible to get them to come out like the ones on Cervini's car; but I am going to have to work on it some more when I get the car back.
ORIGINAL: Gloves
CDC Holes:
I did have to fill the holes in the top.
The shop did such a nice job, i couldn't even tell they were ever there.
CDC Holes:
does it come with something to line the holes up perfectly, or is that all measurments?
