Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > 2010-2011 Mustang Technical Discussions
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-12-2009, 11:43 AM   #21
Napoleon85
Vehicle: 2010 Mustang GT
Send a message via AIM to Napoleon85
Quote:
Originally Posted by GT_n00b View Post
It makes since you can't use NTFS since its a Microsoft proprietary file system format.
Actually, it's ironic that these can't read NTFS since MS designed the system. That aside, NTFS is not a great format for portable storage. FAT32, despite being old and decrepit, is still the best format for all-around compatibility.
I got one of these [newegg.com] and tested it against some of the other mainstream flash drives. They all have good throughput but this has the best random access times that I have found which makes it ideal for reading lots of small files on demand (such as songs). It's won the customer's choice award 6 times and is only $17 (after rebate) with free shipping. Even at the $27 (before rebate) it's a good deal.
__________________
2010 Mustang GT - Grabber Blue - Track Pack - Purchased 9-23-09
*sold 9-14-09* 2006 Legend Lime Auto 4.0 / C&L CAI / Bama 93 Race tune / Single GT Takeoff
Napoleon85 is offline   Reply With Quote
Old 09-12-2009, 12:04 PM   #22
GT_n00b
Vehicle: 2010 GT Mustang Coupe
Quote:
Actually M$ only provides the SYNC software portion of the system and didn't actually design the Shaker 500/1000 which is what reads the thumb drive.
GT_n00b is offline   Reply With Quote
Old 09-12-2009, 12:12 PM   #23
bgmikejr2009
Vehicle: 2010 Ford Mustang GT
Send a message via AIM to bgmikejr2009 Send a message via Yahoo to bgmikejr2009
To All:
The reason they did not use NTFS is NTFS is used for permissions in Windows and FAT32 is much quicker when accessing files on a flash drive or any type of drive that you are using, bottom line is FAT32 is what is used in cars with USB thumb drive connections for the radio due to NTFS being created for better permissions on files in Windows. NTFS is a windows based file system and Windows is not used in the shaker 500/1000 systems so there's the truth behind it all.
Take care all
bgmikejr2009 is offline   Reply With Quote
Old 09-12-2009, 12:22 PM   #24
157db
Got Troy'd
157db's Avatar
Vehicle: 2007 Pony Package
Quote:
Originally Posted by bgmikejr2009 View Post
To All:
Take care all
Yea, no MS in the SYNC.
Its all proprietary SpanishOak stuff.....
__________________
NON PUMKIN JACKER
Quote:
Originally Posted by Boozshey View Post
Oh yeah, I forgot Norm was God on here.
Give me a break!!!
Quote:
Originally Posted by Norm Peterson View Post
<rises to the bait>
. . . Definitely not God.
Norm
157db is offline   Reply With Quote
Old 09-13-2009, 01:03 PM   #25
FordEngineer
2010 Ford Mustang
My Garage
FordEngineer's Avatar
Actually, MS just provides the underlying OS (Windows Mobile Automotive). Ford designs all the applications/interfaces that you work with. Voice Recognition is done by Nuance.
__________________
Ford Vehicle Systems Engineer
Kona Blue
FordEngineer is offline   Reply With Quote
Old 09-13-2009, 01:17 PM   #26
FordEngineer
2010 Ford Mustang
My Garage
Quote:
Originally Posted by Sarge2155 View Post
I am not having any luck finding a USB drive that will even work in my Stang. What brand name is everyone using? Exact models and brand names would be helpful. I have tried two so far both FAT32 formatted. The system will not play my mp3s. They are not protected just regular mp3s, system says it is not able to play....what gives?
Let me make sure we've covered everything:
1. You insert the USB stick into the USB port in your center console
2. You press the voice button on the steering wheel (Talking head icon), NOT the media button (music note). It's a double-sided button, if you press the wrong side, it won't do what you want.
3. You're presented with a voice prompt:
YOU HAVE NAVIGATION
4A. "Please Say a Command"
YOU DON'T HAVE NAVIGATION
4B. "[SYNC]. Please say a command." (SYNC could be a number of audio sources... see http://mustangforums.com/forum/2010-...-commands.html)
If you've gotten this far, we're good. If not, there's a more serious problem.
If you HAVE gotten this far, say 'SYNC' if you have navigation (you'll then get a voice prompt that sounds like 4B). Proceed at the next step. If you don't have navigation, just skip to the next step.
5. Say 'USB' after the 'listening' tone (sounds like 'bing')
6. SYNC should say something that starts with "SYNC has detected a new device. For your safety please stay alert to changing road conditions and use SYNCs voice-activated features while your vehicle is in motion." You may also hear a message about playing protected content. (this only happens the first time you put in a new USB device). I forget whether or not it starts playing media at this point or not.
7. Press the voice button again, and if the audio source is 'USB', you can say 'Play all' to begin playing all of your music (see the link above for playing media by artist, genre, album, and so on).
If you still have problems accessing the USB drive, it may have not been plugged into the module all the way at the factory, or it could be the result of a PCM software issue (not sure how the powertrain affects the SYNC module, but I digress...).
In any case, you'll have to take it to the dealer for a free fix (both are easy, quick fixes). If the USB cord from the module to the port is plugged in securely, then you need a PCM flash to upgrade the software. Reference TSB# 09-14-3.
__________________
Kona Blue
Old 09-13-2009, 08:23 PM   #27
Sarge2155
Vehicle: 2010 Ford Mustang GT Premium
Quote:
Originally Posted by jocatch View Post
My flash is Corsair but any drive formated properly should work. Are you sure the USB port is working? Somewhere on this forum I think someone had a bad connection and their port was not working.
Joe
Yes I am sure the USB port works because it registers something inside it (the port) it just will not play the mp3's. The Synch also talks so yes the port works.
__________________
2010 Mustang GT Premium
5 Speed Manual Transmission
Sterling Grey Metallic
Charcoal Black w/Cashmere Accent
Premier Trim Color Accent Package
Comfort Package
Security Package
3.73 Package
19" Premium Painted Luster Nickel Wheels
GT Coupe Accessory Package 5
Shaker 1000 Audio System
Sarge2155 is offline   Reply With Quote
Old 09-13-2009, 09:10 PM   #28
Sarge2155
Duh I got it to work. I was using a bad command..when all else fails pull out the book. I was saying play instead of play all. Works like a charm I feel so stupid now.
__________________
Comfort Package
Security Package
3.73 Package
2010, aac, camaro, drive, files, ford, format, large, music, mustang, play, problem, sync, thumb, usb
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
