Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > 2010-2011 Mustang Technical Discussions
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-05-2009, 12:25 AM   #1
10GTPony
2010 Ford Mustang
10GTPony's Avatar
Vehicle: '10 Mustang GT
Default 2010 Ford Service Literature: "One Time Use Fasteners"
On what little factory service literature I've come across for the 2010 Mustang (and I'm know this applies for models prior to 2010), they often state (paraphrasing) --
Some factory fasteners are intended for one time use only.
And this seems to be a blanket statement across many pieces of factory literature -- so who knows what it applies to.
Where/what are of the areas of the vehicle which would most likely contain these "one time use fasteners"?
On a separate note, I sure wish I could get my hands on the OEM Factory Service Manual without paying up the nose for it (e.g., on HelmInc.com for $1K-$2K+, but it's not even available yet.)
__________________
Current Ride:
• 2010 Mustang GT, 5 spd •
Rides of the Past:
1990 Mustang 5.0L LX Hatchback, 5 spd
1987 Mustang LX Convertible, A/T
1966 Mustang Coupe, A/T
10GTPony is offline   Reply With Quote
Old 10-05-2009, 02:16 AM   #2
Donnie's GTS
Donnie's GTS's Avatar
Vehicle: 01 Ford Mustang Bullitt
all of the spring clamps holding your hoses on. If you ever take them off, they need to be replace with adjustable hose clamps
__________________
Bassani catted X. Pypes Violator Catback. 1/8th: 8.9@81mph 2.13 60ft.
Donnie's GTS is offline   Reply With Quote
Old 10-05-2009, 02:30 AM   #3
10GTPony
2010 Ford Mustang
10GTPony's Avatar
Makes sense.
I once read, I believe, where auto makers sometimes equip various engine parts with fasteners (bolts, in particular) that have variable tensile strength that can expand as much as a couple percent when tightened to the factory specified torque.
So removing the nut essentially dictated the necessity to replace it with a new one.
And needless to say, some of the fasteners they use are custom made, not just off the shelf bolts.
__________________
Current Ride:
Rides of the Past:
Old 10-05-2009, 04:40 PM   #4
JOHNNY
Vehicle: 2005GT/VERT-2010 gt500
Don,t use adjustable hose clamps on anything plastic replace with new sping clamps.If adj. clamp is over tighten the plastic will crack right under the clamp.
__________________
1970BOSS429, 2005GtVERT ,2008 GT500VERT
JOHNNY is online now   Reply With Quote
Old 10-05-2009, 05:06 PM   #5
FordEngineer
2010 Ford Mustang
My Garage
FordEngineer's Avatar
Vehicle: 2010 Mustang GT
There's also one-time use fasteners that hold the wheel assemblies and spindles together, as well as certain suspension parts. They need to be replaced if you take them apart. Some have built-in grease assemblies that can become depleted or contaminated if removed (causing critical failure), but more importantly, re-tightening/constant torquing back and forth to loosen/tighten certain fasteners can fatigue them, and you don't want fatigue on any part that can result in a wheel coming off.
__________________
Ford Vehicle Systems Engineer
2010 Ford Mustang GT
Kona Blue
FordEngineer is offline   Reply With Quote
Old 10-05-2009, 05:42 PM   #6
10GTPony
2010 Ford Mustang
10GTPony's Avatar
Quote:
Sounds very plausible.
Let me put this to you FordEngineer:
Would the Strut Mounting Bolts (I'm talk about bolt studs inside the engine bay -- mounting the struts to the frame) be something that are considered one time use bolts? (My guess: no)
These bolt studs are quite 'beefy thick'.
I bring up the the Strut Mounting Bolts because I did remove them for installing a Tower Brace (not a problem there, I believe), yet could see removing them again (and again) down the road in order to do future engine work (which requires removal of the brace)?
So yea or nay in removal and replacement of these Strut Mount bolts (multiple times over the course of the vehicle's life, without replacing the bolts) and feel that I'm not compromising my suspension?
__________________
Current Ride:
Rides of the Past:
Old 10-05-2009, 06:50 PM   #7
zanypunk
They're are cheap to manufacture so that's why ford installs them. Plus those one time fast.... aren't that cheap if you want to get them from the dealer so Ford ends up getting a couple of your bucks if you intend of doing some body work.
zanypunk is offline   Reply With Quote
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
