Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > 2010-2011 Mustang Technical Discussions
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-17-2009, 04:28 PM   #1
FastDEW
Vehicle: 2003 Ford F150
Default What is the best solution for Axle Hop?
So I am seeing three different fixes.
I see that some live by replacing the Upper Control Arm.
Still others say you only need to do the Lower Control Arm.
Then you have even others that say you have to do both.
In another thread, I read the following solutions:
1. The Roush UCA.
2. The Steeda UCA and LCA.
3. The UMI position changed LCA.
And on the American Muscle store website they sell J&M lowers and uppers. If you read the information on them, they both say the reduce axle hop.
Which of these really works, or if they all work, which works best?
Which is best for limiting axle hop?
Which is best for maintaining ride quality?
Which is best for keepling NVH (Noise, Virbration) Low?
Which is best for keeping stock handling?
Since the lowers are far easier to change than the upper, is that the place to start and does it work?
Who has done any of these? Input and opinions - But please include real informaiton.
Thanks!
__________________
*Delivery Date = November 25th * 2010 Ford Mustang GT Premium, Manual, Kona Blue / Charcoal Interior, 3.73, 19" Wheels, HID, NAV, Rr Vid Cam, Comfort, Security, Packages.
FastDEW is offline   Reply With Quote
Old 10-17-2009, 07:57 PM   #2
Lv XLR8N
Lv XLR8N's Avatar
Vehicle: 2010 Ford Mustang GT
Well I am planning to buy Lowers and Uppers from BMR for my 2010.
When I had my fox body, I did the lowers, and that took care of any wheel hop I had. The stock stamped steel pieces are just not good enough, too much flex.
__________________
2010 Ford Mustang GT Premium, Grabber Blue, (401A) Premier Interior Char /w Grabber Blue Stripe, 5-Speed, 3.73 rear, Roush Off-Road exhaust, more to come...
Lv XLR8N is offline   Reply With Quote
Old 10-17-2009, 11:30 PM   #3
FastDEW
If the lowers cured your older Mustang, why go right to uppers and lowers on the new one? What reason?
__________________
Old 10-18-2009, 10:46 AM   #4
Lv XLR8N
Lv XLR8N's Avatar
I am replacing the upper due to its still weak light gauge stamped steel, I am already going to be under the car replacing the lowers. The upper to my understanding maintains pinion angle and prevents axle counter-rotation. For less than $200 it can't hurt.
I dont have any real proof that its better to do one or the other, and only had my old car as an example. In my experience the lowers made a difference. Hopefully someone who has done this with their 05+ can chime in.
__________________
Old 10-18-2009, 11:28 AM   #5
Doogie65
2007 Ford Mustang
Vehicle: 07 GT Alloy vert
Every car is a bit different, but a great starting point is any good LCA including BMR, Steeda, CHE, UMI, etc. as the key benefit is the stiffer Poly bushings. LCA brackets can definitely help as your LCA angle can get out of whack if lowered (meaning the front mount gets lower than the rear).
Although the Roush arms are stiffer, they use the same OEM bushing that comes stock on our cars. I found this out after buying a set and quickly sold them... then upgraded to Steeda billets.
Do some searches as this topic gets revisited very frequently, so there is plenty of info to be found on the topic.
__________________
Mods: Edelbrock Supercharger 422RWHP/394RWTQ, CDC convertible bar & Classic Chin, Roush rear springs, GTAs, Steeda Billet LCAs & adj. panhard, CHE anti-squat, Pro5.0 shifter with Hurst stick/knob, RotorPro Rotors, Agent 47 mirrors, Dual Aeroforce gauges, CS69 wheels
Foose hood awaiting paint
Doogie65 is offline   Reply With Quote
Old 10-20-2009, 10:09 PM   #6
66FB06GT
Vehicle: 06 Mustang GT & 66 Fastback Mustang
Totally agree with Doogie. A good set up BMR LCA's is probably all you will need. I really like the CHE stuff but they quit making LCA's. Their anti-squats are really nice pieces. Everyone I know runs this setup with great results. The UCA is really hard to install and probably unnecessary IMO.
__________________
FastbackMustang.com
66 Fastback Mustang - 302, C-4, 8" w/3.80 posi
06 Silver GT - 5spd, JLT, BamaChips 93 Race, 3.73, Coast DS, MAC LT's w/ Prochamber, FRPP GTA's, Steeda UDP & Delete Plates, CHE Anti-Squats/DS Loop/K-member brace, BMR LCA, Roush Rear Springs, Black FRPP FR500, Nitto 555
66FB06GT is offline   Reply With Quote
Old 10-20-2009, 10:25 PM   #7
FastDEW
Thanks for the information on this. I ordered the J&M LCAs with the extreme joint. It seems like the extreme joint on the axle end makes sense to me. I will report once I get the car and get them installed.
__________________
2001, axel, axle, car, cobra, f150, ford, hop, mustang
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
