Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > 2010-2011 Mustang Technical Discussions
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-23-2009, 11:36 PM   #1
myarmy2007
Vehicle: 2008 Mustang V6
Default Help with Audio
I have an '08 V6 mustang and anytime i plug in my zune or ipod into the port under the center arm rest and put the stereo on "line in" i can only hear out of one speaker, the drivers side front speaker, i even checked my balance and fade and both are in the center. please help i want to know how to make it so i can listen to my zune on all the speakers
myarmy2007 is offline   Reply With Quote
Old 10-26-2009, 11:45 AM   #2
Popeyejon
2003 Ford Ranger
My Garage
Popeyejon's Avatar
Vehicle: 2010 Ford Mustang GT Prem.
Are you using a 1/8" audio plug? If so, check your plug/cable, it may not be all the way in or may need to be replaced. You can check it by plugging in to one of the inputs on your home system.
Popeyejon is offline   Reply With Quote
Old 10-26-2009, 11:50 AM   #3
10GTSTANG
10GTSTANG's Avatar
Vehicle: 10 Ford Mustang
And using a stereo, not mono cable. If you are, and your device is outputting in stereo then you might have an open in the cable fron the jack to the stereo unit or a loose connector.
__________________
Whipple HO, Kooks Long Tubes, Kooks Catted H Pipe, Magnaflow Magnapacs
502 HP where the rubber meets the screet
497 ft/lbs where the rubber meets the screet
USN Retired
10GTSTANG is offline   Reply With Quote
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
