I've been going back and forth with it. The front end looks awesome where the vent is, but the noticeable crack along the side where it connects to the hood looks a bit cheap.
How does it even attach? Is it just glued on or bolted somehow?
Bolted towards the middle and taped on the sides. This is why there's often a gap between the scoop and the hood. The bolts should have been along the edges.
I dig the scoops on the 10's. I think the best looking one is the GT350, although I think that's the entire hood. Is that hood going to be available anytime soon for you 10' owners?
That hood isnt bad, defintiely better then the ford hood scoop. I doubt this will be available anytime soon and proably will be pricy. But im sure they will make some cheaper knockoffs.
I Don't care for it too much. I think the hood cowel looks good the way it is.
I would go for the 1/4 side window louvers. I had test drove one with the scoop and thought it blocked your vision a little bit.
If Ford could press out a one-piece hood/scoop... that looks identical to this optional scoop but without the separation lines that are clearly visible from this bolt on, I'd buy it in a heartbeat.
