Roush Fascia foglight question?
Old 02-13-2011, 06:49 PM
grabber blue gt
grabber blue gt's Avatar
Default Roush Fascia foglight question?
Well there is one last place I need to check and see if they have the tsw's, but if not I am going to do the Roush front fascia in the meantime since the RTR's ship out March 31st. My questions is, I want to hook up my stock foglight wiring to the new roush fogs since I am using my saleen grille. Do I need to ask for this wiring harness or is it supplied when I order the fascia? Also what is the bulb size for those fogs? I want them to match my 6k hids
grabber blue gt is offline
Old 02-13-2011, 07:24 PM
Wil
Wil's Avatar
I believe when you order the Roush front end, it comes with everything you need including the hardness. I was planning on converting to CS/GT front end but fell in love with the Roush front...saw someone here that painted the middle portion black...looked badass!! Good luck!
Wil is offline
Old 02-13-2011, 08:00 PM
wilkinda
2010 Section Moderator
wilkinda's Avatar
You have to ask Roush to send you the extensions if you are not planning on running the stock GT fogs. Tell them you need the kit for the Stage 3 configuration. This is the exact kit I used
Roush Part#: 403508
: R08080028 - 13 - AA
wilkinda is offline
Old 02-13-2011, 08:22 PM
grabber blue gt
alright, thanks alot I will order it tomorrow.
Old 02-13-2011, 08:57 PM
grabber blue gt
Just saw your response, and btw I am painting the middle portion black as well as around the fogs ;]
Old 03-29-2011, 03:08 PM
msoler
msoler's Avatar
Default Did you get the fascia?
I was just wondering if you got the fascia and if you did end up getting the middle portion painted black. Also, did you use the wiring harness supplied with the front fascia or did you have to purchase the extender wires to extend the factory connectors down to the bottom roush fogs?
msoler is offline
Galactic
04-29-2019 02:56 PM
firecoyote
09-27-2015 02:37 PM
12bigredstang
09-24-2015 10:43 AM
Ipaman
09-22-2015 07:01 AM
warwickbass
09-20-2015 04:51 PM
Quick Reply: Roush Fascia foglight question?
