CS Fascia with Fogs - Keep GT Fog Lights?
Old 07-27-2011, 11:35 PM
pdonket
pdonket's Avatar
Pictures as requested!
As you can see, up close you can see my less than perfect workmanship, but from a distance they look great in my opinion, and it doesn't even take that much distance, only a few feet. I got first in class at my latest car show so I don't think they look too bad at all
pdonket is offline
Old 07-28-2011, 06:23 AM
alan0614
alan0614's Avatar
Hey thanks for sharing, it looks great actually. Do you remember what material you used? Does it have a texture to it, or just smooth?
alan0614 is offline
Old 07-28-2011, 11:41 PM
pdonket
pdonket's Avatar
No problem at all
What I used had a grainy side and then a smooth side, the side I have facing out of the holes is smooth, thought it would likely adhere better to the back of the holes once you rough it up just a little. Next time I run by Lowes I'll try to find out exactly what it was I used, it was in the plumbing department if I remember correctly. Mainly I went in without knowing what I was aiming for though, just went looking for something relatively thick, durable, and plastic to match the composition of the rest of the fascia.
I would guess that any form of roof type, thick flashing or plumbing seals should do the trick. I aimed for about a thickness of maybe 1/8 inch.
pdonket is offline
Old 07-31-2011, 07:04 AM
alan0614
alan0614's Avatar
Thanks again, I will drop by and see what I can find as well.
alan0614 is offline
Old 07-31-2011, 09:34 AM
fc31964
fc31964's Avatar
I dont think this is legal,to run all six at once.
fc31964 is offline
Old 07-31-2011, 03:25 PM
alan0614
alan0614's Avatar
I think the number is state dependent, "facacc" said the number in Ohio is 5 lights. I will check with a cop buddy of mine to see if NC has a light limit.
alan0614 is offline
Old 07-31-2011, 08:27 PM
facacc
facacc's Avatar
It does depend on the state that you live in.
facacc is offline
Old 08-01-2011, 05:13 PM
starbai
starbai's Avatar
I vote for getting rid of the grille fogs altogether.
starbai is offline
Old 08-01-2011, 08:06 PM
alan0614
alan0614's Avatar
North Carolina General Statute (NCGS 23-130B) says you can have as many "auxiliary lights" as you want, but you can only burn two of them at a time in addition to the headlights. Still undecided, wheels first, fascia later.
As always, I do appreciate all of the input, opinions, etc. This is a great group.
alan0614 is offline
Old 08-01-2011, 08:39 PM
AzPete
AzPete's Avatar
I added some small lights behind the grill on my CS and stuck a switch under the hood for maintenance purposes. It activates a relay which then powers the lights. They are on when the car is running as a daytime running light type with the stock lights still as the factory system is setup. I run all six at night and have yet to be questioned in Fl.
You could also use the fog, high beam, or low beam power to activate a relay to power the lights when either one was on.
AzPete is offline
Quick Reply: CS Fascia with Fogs - Keep GT Fog Lights?
