Roush side splitters install?
There are larger plastic clips that push into holes along the top of the rocker panel. Once you have worked the push pins out of the bottom (pulling down on the rocker and using plyers to pull the push pins out), you can start pulling away the top to see the clips. I took a small screw driver and pushed the clip together so it would come out of the hole.
You might have to just muscle it off the first hole so you can see how the clips work. You won't break the clips and you will just have to snap it back into the rocker panel before installing.
There are two different holes. There are shared holes that the Panels and Roush splitters will use. These are the factory push pins you pulled out earlier. The Roush splitters will come with some push pins and those will drill into the Rocker panel to fasten them together. Those holes don't mount to the car, just the panel.
I finally got to do the install went smoothly. Thanks brimy311 your notes helped. I had new rocker panels so I installed the splitters to the rocker panel. Then removed the factory rocker panels then installed the new combo. Easy install only took about 1 hour.
Of the installation? You guys are really over thinking this. It's a simple installation. It took me less than 30 minutes with taking the rockers off my car and washing the lower rocker area.
Roush has installation instructions here:
http://store.roushperformance.com/im...092_manual.pdf
@dcarlinf1 nah I didnt take any pics of the install because well brimy311 was right I was overthinking it. It was very simple. As for pics after the install was done, I dont know how to upload pics onto this site right now.
@brimy311 you were right it was a very simple install. I was asking all the questions before I seen the parts or directions cuz I had it shipped to a friends house. Removing the factory rocker panels was easy just pull slowly n it all comes off. Drilling the holes was also easy I did that before I put it on the car so I didnt need a jack. I just took my sweet ol time
inyadreems
08-21-2015 09:10 AM
