Brembo Packages, Squeaky?
Old 12-05-2011, 09:20 AM
1nsanegt
1nsanegt's Avatar
Default Brembo Packages, Squeaky?
Anyone have the Brembo package and getting an annoying squeak from the brakes under light pressure?
my car has 10k on it, and its a pretty embarrassing driving a 36k car and the brakes squeal like POS.
I just got back from the dealer, and they "couldn't replicate the customers concern" wow thanks.
1nsanegt is offline
Old 12-07-2011, 05:40 PM
CubanoGT
CubanoGT's Avatar
No squeaking here
CubanoGT is offline
Old 12-09-2011, 10:45 AM
GhastlyTT
GhastlyTT's Avatar
My rear driver side squeaks and scrapes when i turn left. Don't know if the rear's are brembo pads or not. Only my front brakes are branded Brembo. Annoying as hell. Gonna take it to Ford soon and have them look at it.
GhastlyTT is offline
Old 12-09-2011, 06:03 PM
rebus
rebus's Avatar
I retro-fitted the Brembo's on my 06, and yes they do squeal under light pressure, and have since day one. Everything was brand new from FRPP, and I followed recommended bedding procedures. One major difference between the stock brakes and the Brembo's that may contribute to the squeal is floating vs non floating (fixed) calipers. The stock Ferodo pads probably also contribute to the noise. Mine doesn't always squeal, but it can be annoying. I usually let up on the pedal then push down again and most of the time it will stop. The price you pay for performance brakes.
rebus is offline
Old 12-09-2011, 06:31 PM
theACE
theACE's Avatar
The squeaking is from the pads being metallic and once your car sits even for a while the breaks build up some stuff on them and will lightly squeak.
I took my 11 v6 in for this problem, no brembos, and my *trusted* service tech advisor told me that. he is not a sleez, I know it was not a lie.
theACE is offline
Old 12-11-2011, 12:40 PM
cbc24
cbc24's Avatar
you are correct itd be the metallic pads, Good performing brakes are suposed too be noisy.. Metallic pads are higher performance pads that grab more but with the fallback of noise, ceramic pads be alot quieter with less performance
cbc24 is offline
Old 12-11-2011, 09:55 PM
CubanoGT
CubanoGT's Avatar
I guess I got quiet brembos lol btw the rear are regular ford stuff only fronts are brembos
CubanoGT is offline
Old 12-12-2011, 06:13 AM
wrxified
wrxified's Avatar
I put a take-off set of Brembos on my v6. Mine don't make squeal at all.
If my brakes have ever made noise it was because I didn't use enough brake grease between the shims and pads. The Brembos use a quick change pad that comes out without having to remove the caliper. The pads are super easy to remove and grease. I'd try that and see if it fixes it.
wrxified is offline
Old 12-13-2011, 04:23 AM
rebus
rebus's Avatar
The FRPP kit came with new front and rear Ferodo pads. They are supposed to be the stock pads used on the GT500. Don't know if the Brembo package uses the same pad material. In my case I think it's the backing plate of the pad as wrxified pointed out. The rear sliding caliper brakes are silent with the same pad material as the front. Brakes squeal for various reasons including the pad material itself, rotor surface condition, misalignment, backing plate lubrication, worn out pads, and so on. Some brake pads come with a brake warning sensor that will emit a squealing noise when the pads are worn to a point where they should be changed. With only 10,000 mi on your car wear shouldn't be an issue yet. Ford should be able to take care of it, hopefully with a little grease, maybe you should let them know they have to drive it to replicate it.
rebus is offline
Old 12-16-2011, 01:01 AM
gt/cs07
gt/cs07's Avatar
The only other thing I have heard of is if you recently rotated your tires and for some reason one wheel was cast differently. Sometimes the extra thickness of a wheel can cause slight rubbing heard only during braking but I have only talked to a few people who had that problem. Not to mention you would see wear on your caliper or wheel somewhere.
gt/cs07 is offline
Quick Reply: Brembo Packages, Squeaky?
