I found a picture with the cs1 wheels on a late model mustang on americanmuscle.com.
its funny how you would find it. search for the nitto invo tires and size 255 35 20, or 295 35 20. it shows the tire with the rim on the mustang.
Steeda front 9.5" wide 275/35-20, tire and wheel 61lbs, +5lbs more than stock......20x9.5 means 45mm offset
Steeda rear 11" wide 315/35-20, tire and wheel 69.5lbs, +13.5lbs more than stock.......20x11 means 59mm offset
This is the setup I'm running, except I'm running a 315/30/20. They are heavier than stock, but I don't care since they're my street use setup. If I was at the strip, I'd be running a weld 10" setup. Cell pics of mine:
