2012 premium Mycolor cluster on a 2012 base
Old 06-12-2013, 01:54 PM
CubanoGT
CubanoGT's Avatar
Default 2012 premium Mycolor cluster on a 2012 base
Has any1 done it? What did it take?,I have searched ALOT can't find a real answer only a lot of maybes I know about the pats, I just want to know if the color features work etc, I found a premium cluster with 20 miles more than my current one for 120 so I jumped on it
CubanoGT is offline
Old 06-13-2013, 10:02 PM
CubanoGT
CubanoGT's Avatar
Well cluster arrived, installed it to check if everything works and the answer is yes all 6 Gage's seem to function as I already knew car wont start (PATs) ill update this post once I go to the dealer.
CubanoGT is offline
Old 06-15-2013, 03:07 PM
CubanoGT
CubanoGT's Avatar
Dealer changed it, car turns on but now the settings involving MyColor are removed (they worked when I tested the cluster) so taking it back to the dealer.
Update: guy had to get some info from a premium equipped mustang (one on their lot) everything now works it looks sick!
CubanoGT is offline
Old 06-16-2013, 07:49 AM
Matt's 95 Stang
Resident Ginger
Matt's 95 Stang's Avatar
Good to hear. I was going to tell you to make sure they update the "build data" in the gauge to make sure the gauge is able to talk with the PCM. Glad you were able to get it all figured out. How much did the dealer charge you for install?
Matthew
Matt's 95 Stang is offline
Old 06-16-2013, 12:37 PM
CubanoGT
CubanoGT's Avatar
150, so happy with it!
CubanoGT is offline
Old 06-16-2013, 11:22 PM
bigD1515
bigD1515's Avatar
Wow thats definitely on my list. How much for the cluster?
bigD1515 is offline
Old 06-17-2013, 09:49 AM
CubanoGT
CubanoGT's Avatar
I bought the cluster on eBay for 120 with identical miles meaning I didn't have to get my miles fixed.
CubanoGT is offline
Old 06-17-2013, 09:53 AM
Matt's 95 Stang
Resident Ginger
WOW! What a find. I dont think I have ever heard of someone being that lucky.
Matthew
Old 06-17-2013, 11:55 AM
CubanoGT
CubanoGT's Avatar
Well it had 47 miles more than my car but by the time I received it and put it on it was identical eBay is ur friend I highly recommend every base model stang to do this makes ur interior a lot better everything in total cost me 270 bucks
CubanoGT is offline
Old 06-17-2013, 12:50 PM
bigD1515
bigD1515's Avatar
I'll have to look into that. If the miles are way off, can the dealer fix them when they do the install?
bigD1515 is offline
Quick Reply: 2012 premium Mycolor cluster on a 2012 base
