Hey heebe geebe, did you do yours? They look perfect, any pointers on installation??
Yeah I did them solo... If I had any tips it would be use a high quality vinyl, double and triple check your placement & on large areas use Windex. If you Squeegee (plastic) from the center out you'll be quite pleased with your work. Use a hair drier and repeat the squeegee process several times when doing it wet before you remove the transfer paper.
Watch Youtube posts over and over to get your comfort level up. If you screw it up just peel it off and try again. I tried my roof dry the first time and wasn't happy with it. Redid it wet and no issues at all.
