3.7L V6 S550 Tech 2015 - 2017 This section is for technical discussions pertaining specifically to the V6 variation of the 2015+ Ford Mustang.
2015 Lemon law buy back
Old 08-29-2016, 06:58 PM
61mcad
61mcad's Avatar
Default 2015 Lemon law buy back
I called a dealer in Gower MO about a used 2015 V6 I was interested in and they said they had to buy it back under the Lemon Law and that the title would show that it was a buy back. Told them no thanks but should have asked what the problem was. Is there something on these 15s that is a constant problem?
61mcad is offline
Old 08-29-2016, 08:40 PM
Tallica4life81
Tallica4life81's Avatar
I heard that they had a bad supplier for driveshafts. That people were getting a weird vibration and noise from the rear that was a common problem on 15's. It was determined the supply wasn't producing proper driveshaft and so Ford had switched suppliers and problem fixed. That's what I heard on a different forum anyways. Could be wrong since I never actually researched it myself but there were more than one guy in same thread same issue.
Tallica4life81 is offline
Old 08-29-2016, 09:11 PM
61mcad
61mcad's Avatar
Anybody know a build date where the problem was rectified? Still looking at 15s as a possibility.
61mcad is offline
Old 08-29-2016, 09:14 PM
Tallica4life81
No I do not. I even saw a different thread and a guy with a stock 16 v6 having the exact issues and the dealer re balanced his shift and it was fixed. I have a 16 v6 with no issues at all and it's not stock and I drive it hard every day.
Old 08-30-2016, 10:53 AM
jz78817
jz78817's Avatar
was it a gray (Magnetic) one?
jz78817 is offline
Old 08-30-2016, 11:08 AM
61mcad
61mcad's Avatar
Yes it was!
61mcad is offline
Old 12-01-2016, 07:29 PM
The_Publix
The_Publix's Avatar
Do you know ~ when they switched supliers? might help anyone currently searching.
The_Publix is offline
Old 04-17-2017, 11:25 AM
ripingitar
ripingitar's Avatar
The d shaft on my 16 did the same thing. they replaced with a new pt no and it was bout 50 % better. They then called Ford tech hotline and replaced the rear end assembly. Fixed... I guess this vib was a multi part issue
ripingitar is offline
NorthAmericanTuning
10-18-2016 09:21 AM
NorthAmericanTuning
10-06-2016 09:05 AM
coffeebowl
5.0L V8 Technical Discussions
07-21-2016 10:58 PM
Steve@CJPP
CJ Pony Parts
12-31-2014 02:20 PM
Steve@CJPP
CJ Pony Parts
12-10-2014 03:29 PM
Quick Reply: 2015 Lemon law buy back
