How to: Turn off advance trac.
#25
#27
#28
Example 1:
You enter the car and turn the car on. You press the button to turn traction control off. Then while holding the brakes hold the TC button down for 6 seconds. Now the advance track is off.. It will remain off. Lets say you now press the TC button. Now traction control is on along with the Advance track. If you want both off again you must repeat the steps.
Example 2:
The car is on, your already have the TC and Advance track off (again this is done by pressing the TC once and then holding the brakes and pressing down the TC button for 6 seconds) and now you turn the car off. If you turn the car on and want them both off you WILL have to repeat these steps again in order to turn them off.
IDK how to be clearer. Hopefully this helps.
#30
Traction Control - Basically when the computer detects a loss of traction, this quickly responds by reducing engine power when necessary and selectively applying brake force to the slipping wheel while transferring power to the opposite wheel. It helps give drivers a more seamless and controlled driving experience.
Advance trac uses ABS, TC, and Yaw Control.
Yaw control - This component helps drivers avoid skidding and fishtailing. When understeer (which leads to skidding) or oversteer (which leads to fishtailing) is detected, the system selectively applies individual brakes and modifies engine power to maximize control
