3.7L V6 Technical Discussions Any questions about the new engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
Added Oil Separator.
Old 03-14-2011, 05:02 PM
Joenpb
Joenpb's Avatar
Thumbs up Added Oil Separator.
I read this thread and thought that an oil separator was a good mod based on my experiences with previous cars and fouled intakes.
Last Friday I received an oil separator from JLT for my 3.7L. It took 2 seconds to remove the PCV line on the passenger side and install the JLT Oil Separator. For those interested it came with the same type of connectors and tubing Ford used on the original PCV line. Their black anodized version even looks like a Ford OEM part. Sweet!
Well I put close to 300 miles (mixed driving ) on the car this weekend after receiving my JLT Oil Separator. So today I was curious as to how much oil it had accumulated.
A fair amount considering only a few hundred miles of driving. Anyway, these things really work!
Joenpb is offline
Old 03-14-2011, 06:56 PM
ibihab
ibihab's Avatar
Wow, that is interesting. Thanks for sharing that and all the fantastic pictures. Nice work.
ibihab is offline
Old 03-14-2011, 07:16 PM
hogasswild
hogasswild's Avatar
Mine collected between a third and a half of the container after about 750 miles.
hogasswild is offline
Old 03-15-2011, 06:30 AM
Upsh1ft
Upsh1ft's Avatar
So, technically this mod could help prevent oil from entering the intake manifold and accumulating on your valves and the like. I'm still confused as to why the engine is designed that way?
Upsh1ft is offline
Old 03-15-2011, 07:14 AM
Funster_2011V6
Funster_2011V6's Avatar
The only reason you see liquid oil in the seperator is because it has cooled and collected. Practically speaking, the intake sucks in oil VAPOR which the engine burns off. In a stock engine, it shouldnt collect more than a film on anything unless you dont change your oil often enough. Yet another reason to use a good synthetic oil with low volitility.
Funster_2011V6 is offline
Old 03-15-2011, 07:15 AM
2005Redfire6
2005Redfire6's Avatar
Very nice setup JLT has there, especially hoses cut and fit to length!
2005Redfire6 is offline
Old 03-15-2011, 07:24 AM
Upsh1ft
Upsh1ft's Avatar
So basically, a non issue?
Upsh1ft is offline
Old 03-15-2011, 10:17 AM
Joenpb
Joenpb's Avatar
Unfortunately not all of the oil vapor does burn off, and the accumulation has been an issue on my cars cars in the past. The real benefit starts after 50,000 miles, when that oil film thickens, turns to sludge, & the build up starts robbing power. The clean up isn't cheap or easy either.
Oil contamination derives from the positive crankcase ventilation valve ( low pressure/high vacuum for positive
displacement blowers) common on most internal combustion engines where vacuum is pulled on the crankcase
by the intake. This contamination occurs when oil vapors exit the crankcase via the PCV valve /vent hose, enter
the intake tract, and create adverse effects such as carbon build-up on valves, pistons, and plugs, as well as
causes harmful detonation. Detonation in many cases causes the ECM/PCM to retard timing, thus creating a
reduction in horsepower.
http://www.haneymotorsport.com/HMS%2...atch%20Can.htm
Joenpb is offline
Old 03-15-2011, 02:45 PM
traxiii
traxiii's Avatar
Not completely true. Until I put a separator in my FRPP GT-40 5.0L in my F150, oil would pool from the PCV at a low spot inside the Edelbrock intake manifold and everything in there would get sticky. Inserted separator and it stays clean. Gotta think the valves and runners were getting some build up too. Put one on my '04 V6 Stang too. The units I have are clear plastic bowls, so you can see the amount of oil in them. Got them from Grainger.
traxiii is offline
Old 03-16-2011, 11:14 AM
FoxThree
FoxThree's Avatar
[QUOTE=Joenpb;7460358A fair amount considering only a few hundred miles of driving. Anyway, these things really work![/QUOTE]
Of course they work, the well designed ones at least. By removing that oil from the intake, you're getting an effective increase in octane, and if you were boosted, you'd be adding insurance against knock/det because of the effective octane increase. (Oil causes det)
FoxThree is offline
Quick Reply: Added Oil Separator.
