3.7L V6 Technical Discussions Any questions about the new engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
feel of the 3.55's versus the 3.31's
Old 06-28-2011, 10:51 PM
sketchy00
sketchy00's Avatar
Default feel of the 3.55's versus the 3.31's
Yep, another gear question. Curious to know if anyone has any experience with the in-the-seat feel of the 3.55's versus the 3.31's. I have a 2.73, (MT) and have picked up a take-off 3.31, but its still sitting in the garage, and am contemplating going one step further to the 3.55. I've poured over the numbers on RPM ranges for each gear so I'm well versed with that, but would be curious to hear of anyone's experience with the actual feel.
sketchy00 is offline
Old 06-29-2011, 06:49 AM
hogasswild
hogasswild's Avatar
I can't say how they feel but after wrx posted some info on different gear sets I would either go with 3.31s of you want to stay stock for warranty issues or just skip the 3.55s and go with 3.73s. I thought the 1-2 shift would be too quick but you only lose 4-5mph off the top and would redline at 37mph.
hogasswild is offline
Old 06-29-2011, 10:04 AM
sketchy00
sketchy00's Avatar
Thanks Hogasswild. Yeah, the 1-2 shift was just one part of it. ...The other influencing factor is the final RPM of 6th. I didn't want the RPM's to go as high as a 3.73 would be for cruising on the interstate at 75mph.
Old 06-29-2011, 02:30 PM
hogasswild
hogasswild's Avatar
Well, if you still have stock 17s, then you could go to 3.31s and eventually go to shorter tires which would effectively increase your gearing as well. The 215/65-17s are 28" tall and my 225/60-17s are 27.6" tall. Part of the reason the performance package did so well in magazine tests is partly because of the 3.31 gears and the 27" tall 255/40-19s tires. I think that effectively increases gearing to ~3.43 or so when compared to 215/65-17. If you want 27" tall 18s, you can go to 255/45-18s. I'm not sure which 17" size you could go to.
Old 06-29-2011, 02:37 PM
sketchy00
sketchy00's Avatar
Great point about the total diameter size. I'm running the 18" wheels with 235/50r. So those calculate out to being a bit taller than the perf pkg tires. So in a way, my setup with 3.55's would narrow the gap between that of a perf pkg with 3.31's. Hmm... hadn't thought of that.
Old 06-29-2011, 02:55 PM
Joenpb
Joenpb's Avatar
Engine noise on the hwy was one of the biggest reasons I upgraded to 3.31s (I drive 70% hwy miles). When I had the 2.73s, cruising in 6th at 80 mph was at around 1900-2000 rpms. The car was very quiet on the flats, but had a noticeable drone under load (uphill climbs) with my Bassani axle-backs. Now with 3.31s I'm at 2400 rpms at 80 mph (6th), the engine now has a low hum but is still acceptable, and the resonance under load of my Bassani's seems somewhat reduced. I feel this is the gearing the car should have come with stock. The 3.73 gears will cruise at about 2800 rpms in 6th at 80 mph (assuming stock tires). I can understand the want for higher gearing, I'm just not sure I would like the extra engine noise at cruising speeds. My guess is you'll be happy whichever you choose, 2.73s are just too tall. Good luck.
Joenpb is offline
Old 07-03-2011, 10:41 AM
D BERRY
D BERRY's Avatar
My car is an auto trans car and I switched from 2.73s to 3.55s, everything else on the car was stock at the time. As far as the feel of the car, it felt slightly faster but did drop the 0 to 60 times by two tenths which is definatly worth the cost. If I'd had 3.31s I don't think I would have changed gears but as it is I wish I'd have gone with 3.73s.
D BERRY is offline
Old 07-13-2011, 11:21 PM
sketchy00
sketchy00's Avatar
For cryin' out loud, I'm still waffling on this. I'm attracted to the notion of it being able to climb through each gear better, while trying to determine if it is still a good balance for me as far as daily driving goes. Its gonne be one of the two; the 3.31, or the 3.55. Just have to make up the mind.
Old 07-14-2011, 03:56 PM
scottybaccus
scottybaccus's Avatar
remember that the 3.55 will have a great deal more stirring of the gears around town, vs the 2.73. I don't mean redline. I mean shift points coming ridiculously soon. You may not notice in an auto, but it will be a work out with a stick.
I ordered a take off set of 3.31 gears from Shelby America for $25 this week. They list a 3.55 for $35 but its out of stock. Pretty low cost for the gamble.
scottybaccus is offline
Old 07-14-2011, 09:07 PM
sketchy00
sketchy00's Avatar
Yep, valid point for sure. I have a 3.31 take-off that I purchased sitting in the garage as well, and was all set to get it installed, but I hesitate for the thought that I've been enamoured by the effects of some of the upgrades. Wow I wish I could drive a 6sp that had a 3.55 in there. I know I suppose I could find a 5.0 sitting on a lot that has a 3.55, but then I'd be a little distracted by a few other things at that point
Quick Reply: feel of the 3.55's versus the 3.31's
