3.7L V6 Technical Discussions Any questions about the new engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
Is this how your 2011+ v6 engine sounds idleing?
Old 02-25-2012, 05:11 PM
xenocide
xenocide's Avatar
Default Is this how your 2011+ v6 engine sounds idleing?
http://youtu.be/OiCwqh74vVw
constant clicking noise, I swear it wasn't there before. showed up when my entire car started vibrating / shaking.
after listening to it on youtube, its had to hear the ticking but its, there.
xenocide is offline
Old 02-26-2012, 12:02 AM
BigRedStang
BigRedStang's Avatar
When it's cold out, yes. When it warms up, I can't hear anything. Does your car shake while it sits in park by chance? mine does When i first start the car up, otherwise it wont reperat itself and i have no clue what it could be. It isn't a constant shake, but rather off and on every 10 seconds or so.
BigRedStang is offline
Old 02-26-2012, 01:53 AM
Funster_2011V6
Funster_2011V6's Avatar
Is it louder near the rear of the drivers-side camshaft cover? If so, ford has a fix for that tick.
Funster_2011V6 is offline
Old 02-26-2012, 02:15 AM
aaquib1992
aaquib1992's Avatar
Even mine has it, and it's an 08 4.0L
Goes away after the engine temp gets to normal levels. Worried me for a while, but oddly it's only when it is very cold outside (just like bigredstang said). And the Ford techs keep saying that it's normal, but you might want to get yours checked out just to be safe (they are two very different engines, after all).
aaquib1992 is offline
Old 02-26-2012, 05:46 PM
xenocide
xenocide's Avatar
It shakes/vibrates anytime i stop. It vibrates when I accel, it makes the noise even after my 30 mile drive home from work.
xenocide is offline
Old 02-28-2012, 07:53 AM
Funster_2011V6
I see you have a tune in your mod list. If it were mine, first thing I would do is reflash to stock and see if it is still there. If so, then take to dealer. Might be a mechanical problem.
Old 02-28-2012, 08:43 AM
Chromeshadow
Chromeshadow's Avatar
I agree with Funster, put the stock tune back in first.
Finding the locations of a noise is usually pretty simple. You can get a mechanic's stethescope from Autozone for $10.00
http://www.autozone.com/autozone/acc...entifier=70131
Or you can use a paper towel tube to locate noises like exhaust leaks, pulley bearings... noises that are from the outside of the engine. Put one end next to your ear and move the other end to different parts of the engine.
You can use a 18" screwdriver, a one inch diameter wood rod to put on any part of the motor that is safe, and stick the other end in your ear. You'll hear internal noises clearly and they'll be loudest when you have it touching the closest to the noise. ie: if the noisiest point is the water pump, the water pump bearing is going out. If the noisiest point is the left valve cover, you have a cam bearing or lifter problem. You need to be careful, you hurt your car if you get something stuck in a moving part.
Chromeshadow is offline
Old 02-29-2012, 06:56 AM
xenocide
xenocide's Avatar
it is coming from the drivers side and the car is bone stock.
xenocide is offline
Old 03-01-2012, 03:19 PM
twinsemi
twinsemi's Avatar
Did I hear an AC pump switch on during the video? Is the heater on defrost or anything like that?
twinsemi is offline
Old 03-04-2012, 10:52 AM
2011V6Conv
2011V6Conv's Avatar
I have a minor ticking/clicking noise when the engine is cold. Left it at the dealer overnight a few months ago so they start it first thing in the morning. They claim there is nothing wrong with it.
2011V6Conv is offline
Quick Reply: Is this how your 2011+ v6 engine sounds idleing?
