3.7L V6 Technical Discussions Any questions about the new engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
Old 10-23-2015, 02:36 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Ford Mustang Powertrain Guides
Print Wikipost
New Mustang but coolant leak near reservoir
Old 06-07-2013, 09:33 AM
tacticool
tacticool's Avatar
Default New Mustang but coolant leak near reservoir
I am not sure if that is anything to worry about...Maybe the clamp on the hose just was not tight enough.
The coolant level has never been messed with it came straight from dealer at the max cold bar.
thanks!
tacticool is offline
Old 06-07-2013, 10:20 AM
kevinmalec
kevinmalec's Avatar
Have you checked to see if there is a crack or puncture hole in the hose where the clamp is?
kevinmalec is offline
Old 06-08-2013, 02:24 PM
Matt's 95 Stang
Resident Ginger
Matt's 95 Stang's Avatar
Its a new car - take it back to the dealer. Even if it is something small they should be the one doing the work on it.
Matthew
Matt's 95 Stang is offline
Old 06-18-2013, 06:59 PM
tacticool
tacticool's Avatar
I will do that this weekend! I've been so busy with work lately...
Old 10-07-2013, 02:51 PM
stpolo
stpolo's Avatar
Curious to know what the dealership said. My 2014 has this same issue. I'm going to take it in, but was wondering what you experience. Thanks.
stpolo is offline
Old 10-07-2013, 03:59 PM
Phyguy
Phyguy's Avatar
My Raptor had the same issue...on the coolant reservoir and on the power steering hose. It's those crappy clamps. They have a tech bulletin written for certain runs of the Raptor and it was covered under warranty. Good luck!
Phyguy is offline
Old 10-07-2013, 04:47 PM
Derf00
Gentleman's Relish
Derf00's Avatar
The clamp isn't tight enough around the hose. Personally, i'd just buy worm clamps at a auto parts store, replace the defective clamp and call it good. The hassle of taking your car in, waiting around for a few hours to fix something that takes a few minutes is just not worth it to me. MY TIME>Cost of clamps and the few minutes to just be done with it.
Derf00 is offline
Old 10-08-2013, 05:03 AM
tacticool
tacticool's Avatar
I went to Sterling McCall Ford in Houston, TX. Great guys fixed it up. They did a 15 min pressure test of the system and it lost 2 psi pressure. All they had to really do is replace the clamp with a much shinier one and moved it upwards. They then re-did the pressure test and it passed.
Old 10-08-2013, 02:12 PM
StangDawg
StangDawg's Avatar
Yes, shinier parts always work better
StangDawg is offline
Old 10-28-2013, 11:59 AM
tacticool
tacticool's Avatar
Uhhhh leaking again... lol
Quick Reply: New Mustang but coolant leak near reservoir
