Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2014 Mustangs > V6 S197 General Discussion > 3.7L V6 Technical Discussions
Sign in using an external account
Register Forgot Password?
Search
3.7L V6 Technical Discussions Any questions about the new engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
Welcome to Mustang Forums!
Welcome to Mustang Forums.
How to improve idle to 3k rpm performance?
Old 01-26-2014, 10:39 AM   #1
Bob T
Bob T's Avatar
Vehicle: 2013 Mustang
Default How to improve idle to 3k rpm performance?
I've been really impressed with the performance of my stock 3.7 V6 with the exception of the idle to 3k rpm performance. It also doesn't help that I have the 2.73 rear gears. I guess one solution would be to put a 3k stall speed convertor in it, I'm sure that would really do it but I don't want to go there....at least not yet.
When I look at dyno tests of some of the popular bolt ons it looks like an aftermarket throttle body really picks up the bottom end.
What modifications have you done that helped the most with the lack of bottom end torque?
Thanks!
Bob T is offline   Reply With Quote
Old 01-26-2014, 01:51 PM   #2
WindyMustang
On mine, the Steeda CAI + BBK TB + a Bama tune (91R or 93R) really did a nice job with beefing up the lower end. Here's my previous thread.
Shorter gears would definitely help with "punch" - but at the expense of gas mileage to a degree.
Hope this helps - and enjoy!
__________________
Project Indigo is online - pics are up here!
Round 1, Round 2, and Round 3 mods are installed...
WindyMustang is offline   Reply With Quote
Old 01-26-2014, 02:12 PM   #3
Bob T
Bob T's Avatar
Thank you for that well written and detailed report on your results!
I can see following in your footsteps with my modifications.
Looking at your dyno graph I see it picked up substantially at 3000 rpm but looks about the same below 2500.
My problem is I have an automatic, I see you have a manual transmission (I'm jealous). My car is painfully slow accelerating from a stop at idle up to 3000 rpm and then it pulls pretty hard. Since I don't have the advantage of dropping the clutch at 3000+ rpm my car needs help below 2500 rpm too.
Old 01-26-2014, 06:31 PM   #4
Siber Express
Siber Express's Avatar
Vehicle: 2013 V6 MCA Performance Package, Comfort Package, Securtity Package and Electronics Package
Best for mine was the BBK Shorty Headers, brought the low to mid range up to a point that it is useable. Just watch out on how much you open up the exhaust to free flowing will cost you down low.
__________________
2013 V6 MCA, Performance Package, Security Package, Comfort Package and Electronic Package
Airaid CAI, BBK Short Tube Headers, FRPP Cut and Clamp X-Pipe, Borla Touring A/B
SMR Member 2408
GMR Member 257
Siber Express is offline   Reply With Quote
Old 01-26-2014, 06:44 PM   #5
hogasswild
Vehicle: 2011 Mustang V6 Premium 6MT
To echo what others are saying the best low end mods are (in order):
3.73 gears/MPT tune
Shorty headers
73mm throttle body
hogasswild is offline   Reply With Quote
Old 01-26-2014, 08:01 PM   #6
Mike1Six
Mike1Six's Avatar
Vehicle: 2014, Ford Mustang, V6 Premium
Automatic here... My biggest complaint is the hesitation when you first drop the pedal. It's almost like the car bogs down for two or three seconds. I've heard the automatic 5.0's suffer from the same thing. I'm 100% certain it's controlled by the ECM and this can be "tuned" out. My wife's CTS it's fully responsive when you press the pedal and that thing is a POS.
Mike1Six is offline   Reply With Quote
Old 01-26-2014, 08:25 PM   #7
Bob T
Bob T's Avatar
Thanks for the responses everyone, very much appreciated.
Mike, I know what you mean about feeling like a bog. I've had my car for around 2 months and I knew that it was strong up top but down on bottom end torque, which isn't surprising for a little V6, but the other day I finally checked out what it felt like flooring it from a dead stop. I almost laughed at the bog and slow acceleration from a dead stop and then it really wakes up at about 3 grand. The lack of bottom end torque is really this engines achilles heal.
Old 01-27-2014, 01:58 AM   #8
Siber Express
With the Shorties running the rest of the exhaust Stock it was a steady pull from around 1500 on up, where before when you hit 3000 RPM it would almost jump.
For the Throttle lag on the Auto a Tuner will get rid of that. I have a Manual so I don't have the Lag taking off in drive but it still had slow Throttle Response hitting the throttle that I lost most of with the Tune.
__________________
SMR Member 2408
GMR Member 257
Old 01-27-2014, 10:22 PM   #9
WindyMustang
Anyone tried a higher stall converter on an auto? That might help a bit too...
__________________
Old 01-28-2014, 11:04 AM   #10
Bob T
Bob T's Avatar
I've used higher stall speed converters on other cars but not this one.
But I can pretty much guarantee if you put a 3k stall converter in one these cars, end of problem. However a good converter is pretty expensive and a lot more work to install than the other modifications mentioned and probably drop the gas mileage some.
(edit: if feels like the power jumps up at 3000 rpm but then again the torque peak is at 4250 so it may need a little more than a 3k converter if that route is taken)
MustangForums
Ford Mustang
Paid Advertisement
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Emails Backup
