3.7L V6 Technical Discussions Any questions about the new engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
2.5'' vs 2.25'' exhaust piping?
Old 03-07-2014, 08:17 AM
Matt's 95 Stang
Resident Ginger
Matt's 95 Stang's Avatar
Default 2.5'' vs 2.25'' exhaust piping?
Has anyone seen, or know of any dyno feedback for our 3.7s based on exhaust size? More specifically if they benefit more from 2.25'' exhaust cat back pipe size vs 2.5''? I ask as I am getting Magnaflow Competition axle backs which are 2.5'' inlet where the rest of our piping is 2.25. I would like to replace the factory piping as I have seen how bent and restrictive the OEM pipe is.
Thanks!
Matthew
Matt's 95 Stang is offline
Old 03-22-2014, 12:07 AM
13V6coupe
I drive a V6 because I'm a giant wimp
13V6coupe's Avatar
so did you have this done and have some results to share. Seems no one else had an experience with this.
13V6coupe is offline
Old 03-26-2014, 01:32 PM
Matt's 95 Stang
Resident Ginger
No not yet. I am going to wait a few weeks and see if anyone has anything to say. If not I will just take the plunge and do a custom 2.5 hybrid H/X pipe.
Matthew
Old 10-31-2014, 11:47 AM
289hipo
289hipo's Avatar
My MBRP axle back is 2.5 which fitted over my 2.25 factory pipes without a problem.
289hipo is offline
Old 10-31-2014, 02:25 PM
Derf00
Gentleman's Relish
Derf00's Avatar
You can go with a larger diameter pipe if you want but there will be zero performace gains from it. If anything you may lose a little on the low end. This is not due to backpressure (internet folklore) but to a reduction in scavenging affect.
The scavenging effect is created by the velocity of the exhaust in the exhaust pipes that creates a weak vacuum at the head. This weak vacuum helps to pull out the exhaust from the combustion chamber during the exhaust phase. When you increase the exhaust tubing diameter you reduce the velocity of the exhaust gases and therefore lower the amount of vacuum. This lower vacuum will reduce the scavenging effect and thus lower the power a smidge. In most cases you won't notice it by butt dyno. Only on a real dyno...unless you go like 3" exhaust...
There are more technical articles than this but it's the general principle in a nut shell.
http://en.wikipedia.org/wiki/Scavenging_(automotive)
Derf00 is offline
Old 11-02-2014, 01:58 AM
cruisin5268d
cruisin5268d's Avatar
Stick with the stock size.
cruisin5268d is offline
uedlose
The Racers Bench
10-01-2015 08:31 PM
b8checker
09-30-2015 07:11 AM
MustangV6P
09-28-2015 11:00 PM
popsotto
09-28-2015 06:58 AM
09-24-2015 09:18 PM
Quick Reply: 2.5'' vs 2.25'' exhaust piping?
