JLT oil separator install question - MustangForums.com
3.7L V6 Technical Discussions Any questions about the new engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
Sponsored by:
Sponsored by:
Old 04-18-2014, 08:04 PM   #1
Bob T
Bob T's Avatar
Default JLT oil separator install question
I know this should have been an easy one minute install, and it was, except the sticker on the hose that has an arrow pointing "to intake" is pointing towards the valve cover and not the intake.
My very first modification on this car, and an easy one at that, and I need to verify I installed it correct.
It looks like you can only install it one way, and mine matches the images on the American Muscle website.
See attached image and tell me what you think.
Bob T is offline   Reply With Quote
Old 04-18-2014, 08:28 PM   #2
Moderator
JimC's Avatar
You have it installed correctly. The hoses are actually for a different vehicle (can't remember which one) and they are cut for the JLT to fit properly. It isn't necessary for it to flow in that direction because it is only a straight piece of hose on each end of the unit.
JimC is online now   Reply With Quote
Old 04-18-2014, 08:45 PM   #3
Bob T
Bob T's Avatar
Thanks JimC!
This is the first of what I hope to be many modifications. A simple modification but still excited to make the first one!
Old 04-24-2014, 09:40 AM   #4
AMDanBailer
Platinum Sponsor
AMDanBailer's Avatar
Quote:
^ This is correct. You have the Separator installed correctly. Good first mod! What else do you have planned for your car?
-Dan
AMDanBailer is offline   Reply With Quote
Old 04-24-2014, 03:13 PM   #5
Bob T
Bob T's Avatar
Quote:
-Dan
Glad you asked!
I plan on doing some of the typical mods like CAI, tune, headers, maybe gears, maybe driveshaft, maybe suspension mods, possibly leading up to a procharger. Undecided at this point on how far I want to take it.
The V6 project car that you guys have is an excellent blueprint and one that I will be referring to, no need to re-invent the wheel if someone else has already done the research for you.
I do have a question about prochargers on these cars for you.
These engines already have a pretty high compression ratio, I'm wondering how you can add forced induction with say 6-8 lbs of boost on something that is already high compression and borderline on pump gas. Maybe you've already covered this and I missed it.
How much power difference would you see on say a 2013 V6 Mustang with a procharger, one with pump gas and the tune optimized for that, and one with race gas and the tune optimized for that?
Thanks!
Old 06-18-2014, 04:59 PM   #6
CCXVI
What does this mod do?
CCXVI is offline   Reply With Quote
Old 06-18-2014, 09:11 PM   #7
Joenpb
Joenpb's Avatar
Its preventive maintenance, that minimizes pcv oil vapor entering the intake, condensing, & forming a gunk film.
Joenpb is offline   Reply With Quote
Old 06-19-2014, 12:47 AM   #8
CCXVI
Seems useful. Is this a bigger issue with this motor? I've never heard about it on any other car.
Old 06-19-2014, 10:31 PM   #9
Joenpb
Joenpb's Avatar
Fords have quite a bit of pcv blowby in part because 5w20 oil evaporates more. So i tried heavier weight oil, but after a few used oil analysis's, the engine preferred 5w20 oil. So I've stayed with it.
Old 06-20-2014, 10:36 PM   #10
CCXVI
Good to know, thanks.
2014 Sterling Gray Track Pack GT spectreman Mustangs For Sale 23 03-31-2016 10:26 PM
2002 Mustang GT Premium 5 Speed JonnyBlazeGT Mustangs For Sale 3 11-03-2015 02:10 AM
Did a few mods this summer... drfister 2005-2014 Mustangs 9 09-04-2015 08:47 AM
First Time Stang Owner In Norfolk! SterlingStunner New Member Area 6 08-27-2015 12:33 PM
2013 GT500 GB/BS, 3,700K miles, All options except glass roof, 8yr/36k mile ESP inyadreems Mustangs For Sale 2 08-21-2015 10:10 AM
