3.7L V6 Technical Discussions Any questions about the new engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
New Gears at 7K miles
Old 06-20-2015, 08:06 AM
Jerm-79
Jerm-79's Avatar
Default New Gears at 7K miles
I was wondering if it would be okay to reuse the original bearings when I swap out my gears here soon. They only have 7K miles on them and I haven't really beaten up the car. I figured it would save me a few steps on the install process plus prevent me from having to purchase the install kit. I already plan to reuse the shims and I'll be using Ford gears to ensure I have an identical sized product gong back in.
If anyone has done this, please let me know. Also, if you've ever done the swap yourself, I'd love to hear about your experience. I have a lift and all the tools needed. I just have no experience on this particular job.
By the way, I'm going from 2.73s to 3.73s. I'm pretty damn excited!
Jerm-79 is offline
Old 06-20-2015, 09:04 AM
jwog666
jwog666's Avatar
i would install a new inner pinion bearing on the new pinion, this serves 2 purposes, 1 you dont have to take a chance on damaging it on removal, 2 if u ever intent to revert back to stock at any time, the pinion depth will not have to be adjusted as the stock shim is still pressed onto the stock pinion under the bearing. the rest of the bearings can be reused. the swap is pretty straight forward, the only thing you have to check is pinion depth to select the right pinion shim. i use the ford special service tool, but i am sure there are aftermarket tools available to measure this as well, alsomake sure u get a programmer so you can adjust for the new ratio
jwog666 is offline
Old 06-20-2015, 09:48 AM
Jerm-79
Jerm-79's Avatar
jwog666, I was going to have to pull the pinion bearing anyway. I don't want to have to guess at the shim thickness when setting pinion depth so I was going to reuse that shim too.
Jerm-79 is offline
Old 08-11-2015, 11:56 AM
JayBeStangs94
JayBeStangs94's Avatar
Let me know how the install went. I'm getting my 3.73s installed today, couldn't be more stoked! But I gotta wait a couple days to pick up 😐
JayBeStangs94 is offline
Old 10-28-2015, 12:45 PM
Choppertwo
Choppertwo's Avatar
I want new gears as well, anybody from Hagerstown MD know of a shop?
Choppertwo is offline
Old 10-28-2015, 01:00 PM
ucinn
ucinn's Avatar
Can the dealer do this job? Or would a performance shop be a better deal to go with?
ucinn is offline
Old 10-28-2015, 02:18 PM
jwog666
jwog666's Avatar
any competent mechanic can perform a gear swap
jwog666 is offline
KingRando
10-02-2015 08:06 AM
musnicki
09-23-2015 07:11 AM
ccdguy
09-19-2015 05:20 PM
Pyrate Dave
09-10-2015 07:30 PM
Quick Reply: New Gears at 7K miles
