351 Mustang
how much power can a 351w block take
Old 03-07-2006, 08:10 AM
Melon
Melon's Avatar
Default RE: how much power can a 351w block take
thanks for all the info i don't really want to blow my motor but if it happens it happens as long as it after some use and i have enuff money saved up for a dart block or man of war block. and i figure i would just run the t-5 untill it gose boom i just rebulit it less then 1k ago. i just hope i can make it this whole summer at least runing around 500-550 horse all of the time well not when i'm cursing because the sweet thing about turbos is if you don't get on the gas you don't hit boost
Melon is offline
Old 03-07-2006, 11:28 PM
tinman
tinman's Avatar
I think they are 'safe' to about 600-625 unless Dick Sherman gets near it with a lot of high-dollar stuff and then it can make 750+ -----ALL MOTOR.......
tinman is offline
Old 03-08-2006, 12:41 AM
mkspeed26
mkspeed26's Avatar
ORIGINAL: Tims 88GT
get a g force, not a tremec. a tremec is notchy kinda ruff shifting. but a g force wines a lil. so take your pic. or you can go with a t-56 viper trans thats going in mine.
not true. the new TKO600s are a the best on the market by far.
mkspeed26 is offline
Old 03-08-2006, 01:40 AM
S351R13
S351R13's Avatar
The new style TKOs' are great as long as you don't have to shift just above 6500 rpm's. They don't want to shift in that range.
S351R13 is offline
Old 03-09-2006, 08:34 AM
Melon
Melon's Avatar
okay my next question is when i start to crack the block will it be ovbious all of the motors i have blown before were rods going trough the block or cranks snapping i have never had craked or split block before but this is my frist ford.
Melon is offline
Old 03-09-2006, 10:37 AM
393Bird
393Bird's Avatar
My Brother in Law has a 351 stroker that dynoed at 850 HP. It has a girdle, and the block is partial filled. Above that, you need a after market block.
393Bird is offline
Old 03-09-2006, 12:13 PM
88BlueGT
88BlueGT's Avatar
ORIGINAL: grabbem88
yeah,cause a tremec wasn't designed for the weak wristed...
my tko is notchy on street duty,but racing it's smooth as butter.
remember the 351 w is a 302 block.
ORIGINAL: Tims 88GT
Kind of confused on that comment....?? Its a different block.
88BlueGT is offline
Old 03-09-2006, 12:14 PM
88BlueGT
88BlueGT's Avatar
ORIGINAL: r.barn
the block is your weak link.
Most people say to go with Dart block
over 500 hp.
You can probably get by for a while
but dont be surprised if it comes apart on
you one day.
Thats with a 302 block. A 351W block is much stronger than a 302 block. A 351W could very easily support 500hp and if its a block from 74 and under its alot stronger also.
88BlueGT is offline
Old 03-09-2006, 12:16 PM
88BlueGT
88BlueGT's Avatar
ORIGINAL: 393Bird
I also talked to a guy before who ran 800hp on a stock 351W block with a girdle (the girdle doesnt do much though) but it will sometimes handle that much power but when your pushing that much through that block its just a matter of time.
88BlueGT is offline
Old 03-09-2006, 12:17 PM
grabbem88
grabbem88's Avatar
same family block
grabbem88 is offline
Quick Reply: how much power can a 351w block take
