351 Mustang
185s heads too much head for 351
Old 04-13-2006, 01:57 PM
90Mustangfan
I ♥ Acer
90Mustangfan's Avatar
Default 185s heads too much head for 351
what would be better for a 351 the afr 185 or 165. Im probally going turbo right after so keep that in mind...and is 10.1 compression too much for a boosted application. is 9.1 compression just right for turbo?
90Mustangfan is offline
Old 04-13-2006, 09:56 PM
randy78045
randy78045's Avatar
Default RE: 185s heads too much head for 351
Im running afr 205s on my car... as far as power adders go, i understand that lower compression is better...
randy78045 is offline
Old 04-15-2006, 03:04 PM
S351R13
S351R13's Avatar
185s are too small if you plan on using a power adder. 205's are what you should start with.
S351R13 is offline
Old 04-29-2006, 11:55 AM
99saleen351r
99saleen351r's Avatar
ORIGINAL: S351R13
AGREED!!!!
99saleen351r is offline
Old 05-21-2006, 03:52 PM
DARKON
DARKON's Avatar
all a turbo does is essentially up the CR compression ratio.
using 10:1 CR will only inc off boost performance
all you do when the higher CR motor is boosted is use LESS boost than a lower CR motor would
do the 10:1 you will prob be happier with low end and off boost driving
DARKON is offline
Old 05-21-2006, 03:55 PM
grabbem88
grabbem88's Avatar
185's too small for a 351?....ok sure..
grabbem88 is offline
Old 05-21-2006, 05:18 PM
r.barn
r.barn's Avatar
I'm planning on 185's for my 351W, or even TwistedWedges, they'll be plenty of head for that engine.
when i put a blower on I'll just have some port work done to them
to help open up flow
r.barn is offline
Old 05-21-2006, 11:48 PM
S351R13
S351R13's Avatar
That is the same idea as opening up a set of GT40s for a 400 ci windsor. If you start small you can only go so far. Also consider the time and expense when removing and installing heads along with the down time. Pro porting and bench work isn't cheap. You'll have more in port work that just buying a set of 205's and they won't flow with a 205. Before making a purchase you should talk to a reputable shop that builds performance motors daily and handles all the work in house including head porting. A few good shops would be Bennett racing, Keith Kraft, or Pro Line Racing engines.
S351R13 is offline
Old 05-23-2006, 01:31 PM
DARKON
DARKON's Avatar
i dont want to steal this thread ...
but how about a pair of mildly ported gt40p on a 351w? would those be too small. i am looking for 300-400 whp
DARKON is offline
Old 05-23-2006, 02:59 PM
r.barn
r.barn's Avatar
those would be a bit on the restrictive side, i think the P's had smaller
valves, if i remember right.
i would stick with at least one of these heads.
AFR165
Twisted Wedge
Edlebrock RPM
ORIGINAL: DARKON
r.barn is offline
GimpyHSHS
19
12-19-2023 01:12 PM
mustangheaven
01-03-2016 11:20 AM
kevsgt
10-09-2015 10:12 PM
Florida Regional Chapter
09-30-2015 08:04 PM
Drastang
09-30-2015 03:48 AM
Quick Reply: 185s heads too much head for 351
