351 Mustang
351W carb setup fuel Sys ??
Old 09-03-2007, 08:38 PM
Matt Paul
Matt Paul's Avatar
Default RE: 351W carb setup fuel Sys ??
Heres what I did its was cheap and fast.
Matt Paul is offline
Old 09-03-2007, 09:15 PM
ddeaton66
ddeaton66's Avatar
nmerril - how was your system set up? pump - to - regulator - to - carb:: without a return??
TIA
ddeaton66 is offline
Old 12-03-2007, 04:24 PM
86_Notch
86_Notch's Avatar
you can buy the summit plumbing kit for @ 200 bucks, it's only -6 line but it will work, it comes with all the lines AN fittings, pump and reg. i've been high 10s with this setup on spray ( altho i know i'm stretching it )
86_Notch is offline
Old 12-07-2007, 05:40 PM
393Bird
393Bird's Avatar
There are a few things wrong with using a EFI pump and lines with a carb. The pump and lines are designed to handle up to a certain HP with high pressure. When you use a 7 psi regulator, you return or restrict every thing above 7, so reduce the level of HP it will suppport. For doing a carb on anything over 300 HP, start fresh with larger lines and a pump that is designed for low press high output.
393Bird is offline
Old 12-07-2007, 06:45 PM
joeymustang
joeymustang's Avatar
i tried to use my stock 190lph on my carb car...it blew the seal of the regulator and overflowed the carburator, my advice? buy the holley blue fuel pump kit, it includes the regulator, my pump is installed where the fuel filter was and i installed a plastic filter just before the regulator without a return line...works like a charm
joeymustang is offline
jwog666
12-27-2021 08:09 PM
4cylinderplus2
10-09-2020 07:45 PM
svfetter
10-05-2015 11:39 AM
mrappe
09-26-2015 10:16 AM
Quick Reply: 351W carb setup fuel Sys ??
