351 Mustang
Stroker Clearance With Windage Tray?
Old 11-23-2007, 11:53 PM
Ford1158
Ford1158's Avatar
Default Stroker Clearance With Windage Tray?
Couldn't find anywhere if a windage tray (Canton) will interfere with the crank/rods in a 351W stroker (400ci+)? How about clearance with a Ford (Crown Vic) oil pan? I figure if the tray clears the pan will also.
Have ARP main studs for windage tray - they look like they have enough length to add ~ 1/2" spacers to get more clearance between the tray and the rotating assy.
Anyone here know? Trying to figure out before buying an engine kit.
Thanks
Ford1158 is offline
Old 11-25-2007, 04:49 PM
COBRABRAT2
COBRABRAT2's Avatar
Default RE: Stroker Clearance With Windage Tray?
i have a Moroso tray and Motorsport pan. no problems on a 351 not stroked. You will have to mock it up and if needed get out the grinder or whatever it takes to make it fit. If its MAJOR problem, then consider buying a Canton or Moroso pan. The down side of that is I think those pans are a little deeper. That can cause clearance issues with the ground and also even the K member.
COBRABRAT2 is offline
Old 11-27-2007, 10:05 AM
decipha
decipha's Avatar
my canton windage tray says its compatible with strokers... i'm still using stock till i blow it up but im pretty sure it'll fit
decipha is offline
Old 11-28-2007, 01:58 AM
Ford1158
Ford1158's Avatar
Cool -
I don't know who i'm kidding anyway - I wouldn't let a little problem like this keep me from going big.
Ford1158 is offline
Tivo304
08-28-2023 12:19 PM
Brett Ludlow
09-23-2015 06:59 AM
EASTIDEE123
09-14-2015 03:52 PM
vincep99
08-30-2015 11:42 AM
Tyoung68
08-25-2015 04:31 AM
Quick Reply: Stroker Clearance With Windage Tray?
