motor mounts not fitting.
the foxbody 4cyl to 351w swap: i bought 5L motor mounts and when i dropped the engine in they dont line up with the k-member, almost seems the mounts need to be stretched out more. i took off both 4cyl mounts. and the 5L are not on backwards. Any ideas?
Thanks.
Thanks.
RE: motor mounts not fitting.
Did you remove the 4 cyl from the car. Just asking because if the car originally can with a 6 cyl then the K-member is different on the foxbody cars. Other than that I don't know why the mounts would be off. Any photos?
ORIGINAL: S351R13
jwog666
12-27-2021 08:09 PM
logan409
09-26-2015 07:43 PM
