351 Mustang
408 rediculiously simple question
Old 11-29-2007, 05:34 PM
psuhillbilly150
psuhillbilly150's Avatar
Default 408 rediculiously simple question
Ok this seems extreamly stupid of a question to ask but i am gonna throw it out there incase anyone has some slick tricks up their sleeves.
Built my 408 used gray RVT silicone to seal the gap between the intake manifold and the block. LEAKS LIKE HELL. The silicone had set for 3+days untill the motor was run. All serfaces were cleaned with gum cutter 2+2 the nastiest solvent I know of. What else is there to do. Is there a cork gasket that can seal that? I am running a 1986 block with a victor jr intake with vitor jr port matchedheads.
HELP
psuhillbilly150 is offline
Old 11-29-2007, 06:17 PM
r.barn
r.barn's Avatar
Default RE: 408 rediculiously simple question
I would just try again with Black RTV.
Might have just been some bad luck on the leak.
r.barn is offline
Old 11-29-2007, 06:20 PM
Mustangkiler
Mustangkiler's Avatar
ultra black or ultra blue, only way to go.
Mustangkiler is offline
Old 11-29-2007, 07:20 PM
Indy
Indy's Avatar
Don't use the cork stuff! It'll just pop out. I had the same problem, but I use the Blue RTV. I found that I did not have enough PCV (positive crankcase ventilation)! I had 2 breathers on my valve covers and just plugged the PCV port on the carb (you know, just like the showy looking engines in the mags). I pulled the intake back off and re-sealed the lifter valley-intake gap with the RTV. Reconnected the PCV hose to from the carb (could be intake) port to a valve cover with a new PCV valve...and it never happened again.
Now you might already be running the "regular" PCV system and still have this problem. So, you might not have enough vaccum to evacuate the built up pressure in the crankcase, lifter valley etc... you could need an auxillary vaccum pump to evacuate that pressure. IMO.
Indy
Indy is offline
Old 11-30-2007, 01:38 AM
Ford1158
Ford1158's Avatar
Look for the semi-squishy rubber gasket that wraps around both sides of the bottom (like an upside down U) and has waffle texture on top and bottom contact areas that hold RTV and squeeze as needed. I don't know which engines or gasket makers have that but my '91 5.8 and '85 5.0HO did. Dealer might be able to help locate it. Used ultra black RTV.
Ford1158 is offline
Old 12-03-2007, 02:55 PM
86_Notch
86_Notch's Avatar
try with rtv black, put a really thick bead along the block surface and in the corners where the heads meet, and let it set up for a few mins before bolting the intake on. i've made the mistake of putting the intake on too soon and had leaks, hope this helps
86_Notch is offline
Old 12-03-2007, 03:35 PM
aode08
aode08's Avatar
You cant rtv that area with great results, you will need the cork pieces, although I prefer the felpro blue rubber, then rtv the corners considerably
aode08 is offline
Old 12-03-2007, 03:53 PM
aode08
aode08's Avatar
also on your carb gasket to manifold, give him a smear of rtv on both sides all around and let dry overnight before install.
Your gonna have one sick engine
aode08 is offline
chrisdbassplayer
10-13-2015 06:53 PM
treesloth
09-28-2015 07:03 AM
Ipaman
09-22-2015 07:01 AM
Daddys Girls GTs
09-14-2015 08:46 PM
Quick Reply: 408 rediculiously simple question
