1979 351w
1979 351w
I know in the late '70s and early '80s that Ford's engine power went downhill. I know a guy selling a 351w out of a 1979 van. I was wondering if I rebuild it, put new heads, make it EFI with a new intake, and a cam will it push out the same rwhp/rwtq numbers when I put it in my '94 as if i was to do the same modifications to a '94 351w or a '69 351w? If not then which years of the 351w should I stay away from?
RE: 1979 351w
in the mid '70s ford began putting 302 heads on the 351 so if you change those you can get alot of inprovement, a stronger cam always helps since it is the personality of the motor and a good intake to let it all breath and you will be able to put down some decent numbers depending on what h/c/i combo you chose.
RE: 1979 351w
the block ispretty much the same except that the deck height changed in 72 from 9.480 to 9.5 but other than that as far as i know they are the same, they have diff. heads, cam, intake, and probobly comp. ratio. if you used the same pistons heads cam andintake you should have the same power
