Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang > 351 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 02-17-2008, 05:15 PM   #11
psuhillbilly150
1989 Ford Mustang
Vehicle: 1989, Notch
Default RE: extream windsor over hual
compression is all in your hands with your choice of pistons I went with a -5cc piston with a 70cc combustion chamber to get my11:1 ratio. 11:1 is all ya can really get away with on 93 octane pump gas, but you do that its NOx and SOx counts are gonna be way to high to pass any emissions sniffer test.
I don't know what the chambers on the GT-40P heads are but I am sure someone around herecan tell you.
The GT-40P heads are your best bet for less restriction on a budget, at least better then the E7 5.0 heads and your gonna need to get the head bolt holes made bigger to fit the 351 bolts
__________________
408ci, 11:1, eagle forged bottom end, victor jr top, .644/.643 lift 290/302 duration Doug Herbert solid roller. Holly 4150 950cfm to top it all off
psuhillbilly150 is offline   Reply With Quote
Old 02-17-2008, 06:39 PM   #12
92civy
If you ever have plans to boost in the future I owuld go with a 18cc dish piston (Just an example, and what I have) I will be going with a 58cc head, That will give me about a 10.8:1. Thats plenty for the pump gasI want to use.
Then if you even want to add boost all you have to do is get a bigger head. So All I would need to do is get a 72cc head
and boom my compession is back down below 9.5:1.
Nik!
But let us all know what you decide to do.
92civy is offline   Reply With Quote
Old 02-17-2008, 09:24 PM   #13
learning slowlzy
blocks goin to the machine shop monday so i'll know if it will have tobe .040 or .060 over
__________________
i bet i can blow it up
88F250 351 getting stroked and bored .060 202heads forged and roller assy
10/75 datsun 280z w/ C4 street/strip rev. v.body and mounts for the 418to be dropped into
learning slowlzy is offline   Reply With Quote
408w, 414ci, block, bore, bottom, clearancing, notching, require, stroker, strokers, windsor
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
