351 Mustang
351-w Viberation @ 3000 Rpm up.
Old 05-10-2008, 12:33 AM
BlueStanglx
BlueStanglx's Avatar
Default 351-w Viberation @ 3000 Rpm up.
I built a 351-w for my 90 Lx, I just put it in the other day, But @ around 3,000 RPM it will just about shake you out of the car & the oil pressure starts jumpin around... Heres my engine build up, 1990 351-w, Stock crank, turned 10/10, Eagle rods, Kb dome pistons, Cam,Intake with GT-40 heads. I used an 351-w flywheel out of an 1995 Cobra R Mustang. But used my 90 351-w damper... Could some one plz help.
BlueStanglx is offline
Old 05-11-2008, 10:49 AM
Indy
Indy's Avatar
Default RE: 351-w Viberation @ 3000 Rpm up.
Hey,
When you say 3000rpm... Are you revving it in standing still in Neutral/Park when you get vibration? Or are you cruising and get vibration around 3000rpm. If it's while you're cruising than it could be u-joints, driveshaft(bent or outof ballance)etc... But the vibration would occur at different rpm's depending on what gear you are in. If it happens at 3g's standing still, than you have a possiblerotating assembly ballance problem. Also, wear the mains and main bearings installed in correct order, direction and with proper clearances? Good luck!
Indy
Indy is offline
Old 05-11-2008, 10:58 AM
08 Bullitt 2310
08 Bullitt 2310's Avatar
Same here on the vibration problem.Driveline could be pinion angle and many other things.If its when you are sitting there revving the motor,You got a balance issue most likely.Did the COMPLETE rotating assembly get balanced,Which would include the flywheel and damper you used.Ford likes to change up the damper and flywheel balacing every couple of model years it seems.Might need to get that checked out before you break something with that imbalance.
08 Bullitt 2310 is offline
Old 05-11-2008, 12:35 PM
.boB
.boB's Avatar
The balancers and flywheels should be the same, 28oz. so that should be OK.
Is it an rpm issue? Or a speed issue? What year is the stock crank? When you installed the clutch, did you use the dowel pins for the pressure plate? Did you have the rotating assembly balanced for the new pistons and rods? Are all the header tubes about the same temp?
.boB is offline
CS2007
06-25-2019 09:45 PM
TCStangerv6
10-11-2015 05:57 PM
KingRando
10-02-2015 08:06 AM
Florida Regional Chapter
09-30-2015 08:04 PM
09-29-2015 03:23 PM
Quick Reply: 351-w Viberation @ 3000 Rpm up.
