New Features: Ford Mustang Knowledge Base
Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang > 351 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 01-06-2009, 11:43 PM   #1
psuhillbilly150
1989 Ford Mustang
Vehicle: 1989, Notch
Default Rear suspention setup opinions
Car is an 89 notch w/408 motor. I finally have the money to stuff an 8.8 up under the car. I am going with moser setup full spool, 33 spline axels c-clip eliminators, with 4.10 gears.
Now for my suspention,
Granatelli adjustable upper control arms
Megabite lower control arms
shocks are the MMR coilover setup with lakewood 50/50 shocks and QA1 10-150 springs. Torque boxes have been strengthened.
I am running Weld prostars on the back with MT ET Streets 26x10.5 on a 15" wheel.
The opinion I am most interested in is what spring I should run in the rear. Right now I have a set of 4 cyl springs in there that came with the car. Should I be looking for a spring with a 150lb spring rate to match my coilovers or stiffer or lighter? I asked this same question to the guys at MMR but I want to know what others think.
Thanks guys,
Bill
__________________
408ci, 11:1, eagle forged bottom end, victor jr top, .644/.643 lift 290/302 duration Doug Herbert solid roller. Holly 4150 950cfm to top it all off
psuhillbilly150 is offline   Reply With Quote
Old 01-14-2009, 09:14 AM   #2
wildcobrar
Vehicle: 1990 Mustang Hatch LX
I have 3 way adjustable comp engineering shocks on the rear set at 50/50. I have run both 4 cylinder rear sprins and V8 rear springs. There are UPR adjustable uppers and lowers with sperical bushings along with a rear anti roll bar. With the pinion angle set right and the anti roll bar set correctly I have pulled 1.5 60 foot times with mt street car.
Joe
__________________
Always in search of faster ET.
]IMAGE][/IMG]
wildcobrar is offline   Reply With Quote
Old 01-15-2009, 01:11 AM   #3
Slowstang357
1990 Ford Mustang
Slowstang357's Avatar
Vehicle: 1990 Lx Coupe
Send a message via MSN to Slowstang357
4cyl springs in the front to transfer the weight and stiff springs in the rear so the power goes to the ground and no squatting..
__________________
357w, 800dp holley, race c4 3000 stall, 4.10's, m/t 275's, drag suspension, weight transfer work, 2.5" custom o/r h pipe to dynomax race bullets.
Real cars dont spin the front wheels, they lift them.
Slowstang357 is offline   Reply With Quote
megabite, suspention
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
