Well its about that time folks, my 351w 5spd swap has been giving me 6 months of rock solid DDing reliability. Now its time to pull her back out and build her up. Right now I'm doing some parts shopping and I have a list gathering. If you have time check out the list and tell me how you think the parts would work together. If anyone has any engine analyst programs and wishes to input some advice that would be greatly appreciated. I've been searching everywhere and can't seem to find anyone with the exact setup I plan on running although I'm using very common parts. Heres the list currently with links, most everything im ordering from summit unless I find a better price elsewhere.
I already have:
f4te roller block
mallory vac/boost 1:1 afpr
msd 6a & street fire coil
lmaf 90mm
t4m0 ecu & QuarterHorse tuner w/ wideband
edelbrock super victor efi intake
9/16 fuel rails
walbro 255 intank
160 tstat
1200cfm electric fan
oversized radiator
built trans and rear end good for 700hp. I plan on making 700rwhp/900rwtq I'm not going to spin it any faster than 4800 rpms and this is a 100% street daily driver with no track time.
im still looking for 80lb or larger 14.4ohm injectors, 1 5/8 turbo headers that clear accessories including a/c (testing some now), but if anyone has any recommendations or sees a problem thus far please let me know. The turbo is a Borg Warner S475 with a T6 housing and a .96AR from Majestic. I already have 30x mandrel bends of various angles in 3" and 3.5" sizes along with 32ft of 3.5" pipe and 16ft of 3" pipe sitting in my car room next to my 3" I/O turbo mufflers.
I'm looking for any advice at all, I'm itching to spend some money right now just waiting to see what others think
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
__________________
92 tbird 408 turbo 5spd Borg Warner S475mm 1.1AR T6
Tial 44mm w/g @ 11psi tial alpha q bov
8.7:1 RHS heads 2.08I, 1.6X, 64 c/c, 215-I/66-X
Comp Cams 1.6 RR's F303 Cam 226 @ .05, .512 lift
80# injectors, Edelbrock Super Victor EFI intake & elbow
90mm LMAF w/ Mafia Xpander
75mm t/b 4x12x31 intercooler w/ 1200cfm fan
LC1, QH, BE, T4M0-CBAZA
I am not a turbo expert but I can't believe the cam is a good choice. You will need an elbow for that intake manifold. You will need a better fuel system. Good luck.
i have an edelbrock 90mm elbow on the car right now, I'm going with 3x 3/8 runs 2x feed and 1 return, i already have a walbro 255 intank, and another walbro 255 hp external thats going to be wired to a full throttle switch
I didn't think the cam choice was good either, something is telling me to go larger on the lift but im kinda hesitant because of my 4500rpm redline.
anyone else want to chime in with some advice and or suggestions?
__________________
look at comp cams or lunati voodoo. or if you want the most give jay a call. camshaftinnovations.com
from everything ive heard the edelbrock cams and carbs are leavin power on the table
__________________
Quote:
Originally Posted by THUMPIN455
If you take it to the third story and drop it just right it will clearance itself. Might not be pretty or functional when its done, but it would be in there.
sounds sweet. what you gone to do about a wastegate and a blowoff? how about the inercooler? That is a large turbo and the down pipe on that thing is 5in it is gone to be tough running that thing. the F-cam works very well with a turbo but it will leave a lot on the table with the CID you are talking of. why such a low RPM? If you move up to a Custom cam I would call Cam Motion they are one of the best out there with turbo cars. You don't need a stroker to make the HP goals you are saying with that turbo and a 351.
__________________
New low boost times 11 psi 10.91 @ 128 MPH 1.76 60ft 6.98 1/8 mile. still only a 306 CID yes its been a lot faster.
well i did a bit of purchasing since this post here is my current list of parts, all of these parts are sitting in my room right now just awaiting install (im currently rebuilding the engine out of one of my supercharged cars)
f4te 351w roller block
408 forged stroker kit
9:1 CR
arp rod bolts
solid motor & rubber trans mount
k member clearanced 1/2"
hood mount clearanced 1/4"
retaining the stock hood
T4M0 ecu
quarterhorse
innovate wideband
battery relocated to trunk
cross drilled/slotted rotors @4
carbon metallic pads
dual piston calipers up front
I could probably make the power I want with the 351w but mines just so tired it needs a rebuild i have a bunch of blowby and im too scared to do a compression test cuz i know its not running as great as it should. So since im going to rebuild it i might as well stroke and i need all new forged parts anyway so the 408 kit appealed to me.
the f303 cam is plenty since i plan on making max hp at 4k rpms im not revving it anymore than that because this is a 100% daily driver, and all spinning it faster is going to do is cause me to split the block. These stock blocks dont like much over 700 ponies at the back wheels
__________________
I am looking at the almost the same combo that you have (well I am a bit budgeted on money unfortunately..) imho FORGE the crank! If you add too much boost and spin that bad boy up, you will regret not having a forged crank.
I am lookin at the forged eagle kit from cnc, comes with the crank, h beams, and srp -28cc dished pistons to help that boost/compression issue. just my .02
Did you find a turbo kit yet? I have a Brand new, never run B & G hotside for a 351w in a foxbody I'm considering selling
