New Features: Ford Mustang Knowledge Base
Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang > 351 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 06-15-2009, 11:01 AM   #1
luizGT91
Lightbulb what would you do?
hi guys, long time no see,
the stock bottom end of my 93 GT gave up, so i want a new heart for my stang, my combo consists in
Eddy RPM II 1' spacer 75mm TB
TrickFlow TrackHeats with 1.6RR
F303
30 lbs inj 80mm C&L maf
bbk 1 5/8 lts
Spec 2
4.10s
i have a 351 roller laying around and a 351 non roller bored .40 with flat top pistons, a comp cams XE-274-HR, a set of TRW .30 pistons with stock 302 rods with ARP bolts
now here is the question
which combo would work better???
1.- use the 351 roller with the .40 pistons the XE-274-HR and change the lower intake to re-use all stuff to call it a day?? (1 3/4 swap headers)
2.- get a 3.85 crank, use the TRWs = 393! buut will the stuff i already have still work?? (30lbs 75mm TB 80 maf intake)
3.- same as & 2 but with carburator
the only thing that keeps me from going 393+ is my stock t5, i think it would live borrowed time behind a 351, imagen a 393+
let me know what you guys think
thanks
__________________
the last FoxBody - 93 Fobra
the first New Edge - 99 SVT Mustang COBRA
luizGT91 is offline   Reply With Quote
Old 06-15-2009, 04:16 PM   #2
ponyboy88
Vehicle: 1989 LX 5.0 T5
Send a message via AIM to ponyboy88
"30lbs 75mm TB 80 maf intake"
dont think it'll make the cut.
__________________
1989 Mustang Lx Sport 25th Ann. Bolt ons. Big Block Swap in Planning.
1979 Ford Bronco, 4 inch lift, 35 a/t 460 + c6 + np205 d44 and 9 inch, debating dana 60/sterling swap.
ponyboy88 is offline   Reply With Quote
Old 06-15-2009, 09:11 PM   #3
87notch408
87notch408's Avatar
Vehicle: 1987 Ford Mustang Notch
First off I prefer carb all day.
I would use the roller block and stroke it to a 393 or a 408.
I am not sure I am reading it right but the way I understand it you are saying take the XE-274-HR out of the non-roller block and put it in the roller? If so you can not but a non-roller cam into a roller block.
Stock T-5 would not last long. Again I prefer a C-4, just my preference.
I guess it all depends on how much you want to spend and how long you want the car down. If you are looking for budget, just build the 351 flat tappet engine with your uppers and see what happens. You can always change TB etc... later.
Just some thoughts, good luck!
__________________
-Kevin
1987 Mustang Notch
408 Roller Block, Scat rotating assembly, Windsor senior heads, Lunati Voodoo cam, Victor jr intake, BBK longtubes,
C4, Transbrake with full manual reverse valvebody.
Granatelli tubular K member, A-arms, Coilovers and Strange adjustable struts.
Auburn locker rearend, Moser axles, Lakewood traction bars, Competition Engineering adjustable shocks.
4 point cage.
87notch408 is offline   Reply With Quote
Old 06-16-2009, 08:46 PM   #4
sn95_331_GT_ yellow
1995 Ford Mustang
sn95_331_GT_ yellow's Avatar
Vehicle: 1995 Mustang GT
Send a message via AIM to sn95_331_GT_ yellow
i like the idea of the stroker motor, but dong the "ghetto" 393W with the stock 351W rods and the 302 pistons results in 1:a very high compression ratio something close to or north of 11:1. and 2: a VERY unfavorable rod ratio, worse than a 347's.
personally, i like the 408, as it still has a (barely) longer stroke than bore, and gives you plenty of low end torque with enough oomph to rev to 6500rpm.
a torque healthy 408W could get away with the TB MAF and 30#'s but build it for torque, not rpm or itll choke itself.
its gonna still be worlds better than your 302 obviously lol.
__________________
Canary Yellow 1995 Mustang GT
had bolt ons: wasnt fast enough, only beat LT1's.
357W build for about 3 weeks (436rwhp 402rwtq) taken out for my Factory Five '33 Hot Rod
baby boy due 20091203, cars kind of on the back burner (he's gonna help build it).
408W carb'd in the works (block and rotating kit already here).
sn95_331_GT_ yellow is offline   Reply With Quote
1995, 30lbs, 351w, boost, c4, cam, comp, mustang, put, run, stock, xe274hr
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
