Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang > 351 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 06-27-2009, 06:35 PM   #1
redemption
1989 Ford Mustang
redemption's Avatar
Default 351 oil pan
building a 400-430hp 351w carb converted from a 302 1989 lx
just wondering wether i need/should use a high volume oil pump and suitable pan?
im on somewhat of a budget if i can save money in places i will
thanks
chad =]
__________________
357w Heads up and kicking ass
redemption is offline   Reply With Quote
Old 06-27-2009, 09:32 PM   #2
AdderMk2
MF Attention Whore
AdderMk2's Avatar
Vehicle: 1994 Ford Mustang Cobra
Send a message via AIM to AdderMk2
any engine internals are NOT the place to be cheap.
__________________
Siggy removed by Administration.
The Man is trying to oppress me...
AdderMk2 is offline   Reply With Quote
Old 06-28-2009, 03:14 AM   #3
redemption
1989 Ford Mustang
redemption's Avatar
right on brotha
thanks for advice
__________________
Old 06-28-2009, 08:54 AM   #4
87notch408
87notch408's Avatar
Vehicle: 1987 Ford Mustang Notch
I would put in a high volume standard pressure pump and a Canton or Moroso rear sump pan. Make sure you get a pan designed to fit a 351 in a fox body.
__________________
-Kevin
1987 Mustang Notch
408 Roller Block, Scat rotating assembly, Windsor senior heads, Lunati Voodoo cam, Victor jr intake, BBK longtubes,
C4, Transbrake with full manual reverse valvebody.
Granatelli tubular K member, A-arms, Coilovers and Strange adjustable struts.
Auburn locker rearend, Moser axles, Lakewood traction bars, Competition Engineering adjustable shocks.
4 point cage.
87notch408 is offline   Reply With Quote
Old 06-28-2009, 11:05 AM   #5
wildcobrar
Vehicle: 1990 Mustang Hatch LX
Quote:
I agree, extra volume and extra oil capacity is a very good thing. The extra oil volume can help with street driving and will extend valve spring life too. Oil cools the valve springs and the extra volume pump will get it there at lower street engine speeds. Extra capacity also helps allow the oil to run cooler while giving you a reserve of oil for the high volume oil pump's displacement.
Do not forget to add and ARP heavy duty Oil pump shaft as well. Stock one is quite weak.
Joe
__________________
Always in search of faster ET.
]IMAGE][/IMG]
wildcobrar is offline   Reply With Quote
Old 06-28-2009, 04:48 PM   #6
87notch408
87notch408's Avatar
Yes the heavy duty oil pump shaft is a must do upgrade. I have seen standard oil shafts twist in half!
__________________
-Kevin
1987 Mustang Notch
4 point cage.
351, 351w, 50, body, canton, capacity, ford, fox, moroso, motor, mustang, oil, pan, pans, pressure, pump
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
