New Features: Ford Mustang Knowledge Base
Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang > 351 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 06-29-2009, 07:42 PM   #1
92GreyGT
Default EFI 393 throttle body size question
I am building a N/A, pump gas, 393 Windsor engine using a 69' block, DSS rotating assembly, AFR 205 heads, and a Comp Cams hydraulic roller. I am keeping the engine fuel injected and I can't get a straight answer from anyone on what size throttle body to run. I am going to use the Trick Flow intake for the 5.8 but they have two versions, one with a 75mm opening and one with a 90mm opening. Which one do I use? Thanks
__________________
1992 Mustang GT 3375 lbs. w/driver
DSS 331 AFR 165 heads
Comp Cams XE274HR cam
Trick Flow Track Heat intake
Astro Performance Super T5 4.10 gears
Best time 7.58 @ 90 / 11.89 @ 113
333rwhp 357rwtq
92GreyGT is offline   Reply With Quote
Old 06-29-2009, 10:03 PM   #2
Joel5.0
Joel5.0's Avatar
Vehicle: 1986 Ford Mustang GT
90mm.....
__________________
ACRONYMS:
LUK=Let Us Know, GL=Good Luck, LMK=Let Me Know, JIC=Just In Case, BTSTDTRT=Been There Seen That Done That Repaired That, YCYDYP=Your Car Your Dough Your Prerogative and the classic... DILLIGAS=Do I Look Like I Give A S***
1986 GT-X303-289 heads-1.72 rockers-RG 4+1 Trans.
Quote:
Originally Posted by Joel5.0
Great thoughts will overwhelm a feeble mind.
There is never money to do it right, but there's always money to do it over.
The proof of understanding is the ability to explain it. (H. Torruella)
Joel5.0 is offline   Reply With Quote
Old 06-29-2009, 10:12 PM   #3
AdderMk2
MF Attention Whore
AdderMk2's Avatar
Vehicle: 1994 Ford Mustang Cobra
Send a message via AIM to AdderMk2
I hope you are planning on running the Box R
__________________
FOR SALE: 1994 Ford Mustang Cobra #1100
http://providence.craigslist.org/cto/1421116930.html
^^^ Just your average 1.5 ton paperweight! ^^
AdderMk2 is offline   Reply With Quote
Old 06-30-2009, 12:34 PM   #4
fs308
ima ninja
1995 Ford Mustang
My Garage
fs308's Avatar
Vehicle: 87 piece of sh!t
agreed a box r with a 90mm throttle body. the motor is going to require a lot of air to feed it
__________________
Doing a lot with a little
Project:POS build thread
lightweight, stock motor, and 12's?
FOR SALE
***Factory stock diamond pistons .040 over***
***255 3in stroke cheap lightweight crank***
***stock 94-98 headlights***
***351w long block***
other fox stock fox parts
fs308 is offline   Reply With Quote
351, 393, 90mm, body, build, building, determine, efi, ford, fox, mustang, needed, recommended, size, throttle, windsor
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
