Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang > 351 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 07-05-2009, 04:22 PM   #1
MEM 302 5.0L
Vehicle: 1981 Ford Mustang
Default 302efi to 351 carb conversion
what is needed for a 302 efi to 351 carb conversion? i've got a 351 out of an old truck that i'd like to swap for.. the stock hp rating on this 351 is only 170-ish, what is the most restrictive thing on the 1984 carb 351 out of a f150?
__________________
~1981 Notch, GT body kit, and Saleen wing
AOD, w/ 2200 stall, transgo shiftkit, Cold air intake, equal length headers, offroad midpipe, flowmasters, 4.10's, and my smog stuff is removed.
MEM 302 5.0L is offline   Reply With Quote
Old 07-05-2009, 05:03 PM   #2
87Stallion
87Stallion's Avatar
Vehicle: 87 Mustang
I would find a 351W out of a 94+ truck. They are roller cammed.
__________________
87 GT Converted to LX.
GT-40 Heads
TFS1 Cam
Edelbrock RPM Air Gap Manifold
670 Holley Street Avenger Carb
5 Speed 3.55 Gears
351W in the works.......
87Stallion is offline   Reply With Quote
Old 07-05-2009, 05:09 PM   #3
wrenchturner75
1988 Ford Mustang
My Garage
wrenchturner75's Avatar
Vehicle: 88lx
check out the sticky at the top of the forum, lots of good info there. as far as restrictions on a stock 351w well just about everything is, intake sucks, cylinder heads are a joke and the exhaust manifolds are better off as door stops. basically keep the block, crank and rods everything else send to the scrap pile! but as far as individual swap components youll need a oil pan, swap headers, and a 157 tooth 28oz imbalance flywheel or flexplate. and depending on your intake maybe a cowl hood also.
__________________
http://www.supermotors.net/20622 351 cleveland powered, nuff said!
wrenchturner75 is offline   Reply With Quote
Old 07-05-2009, 08:04 PM   #4
MEM 302 5.0L
ok thanks, if i want it to be a roller motor i can just put my 302 lifters/cam in it according to the sticky
it says i need a 28.2oz flywheel, would the flywheel on the 1984 f150 be 28.2oz?
__________________
1981, 351, 351w, 46, 50, body, carb, conversion, cylinder, fox, hp, mustang, ratings, sn95, swap
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
