351 Mustang
need help with a vibration
Old 07-15-2009, 04:18 PM
97modifiedmustangGT
97modifiedmustangGT's Avatar
Default need help with a vibration
We just got done putting a 1993 351w in my buddies mustang. it has just been one problem after another but i won't go into that. since the first drive though it has a vibration from about 2400-2900 rpm. we have a flywheel off of a 68 or 69 5.0 so it should be the right balance unless the crank was changed for some reason in that 5.0 motor. what else could possibly cause this vibration?
97modifiedmustangGT is offline
Old 07-18-2009, 09:06 AM
calfroper_06
calfroper_06's Avatar
Iv been fighting a similar vibration for months now, even had the motor rebuilt and fully balanced.
But things that come to mind, flywheel, crank, harmonic balancer, could even go bck in to the tranny, also could just be the u-joints going out. i would inspect the small things first.
Is it a rpm based vibration, as in sitting in the driveway revving the motor and getting the vibration?
calfroper_06 is offline
Old 07-18-2009, 09:35 AM
393strokervert
393strokervert's Avatar
Default vibration
+1 (Is it a rpm based vibration, as in sitting in the driveway revving the motor and getting the vibration?) (But things that come to mind, flywheel, crank, harmonic balancer, could even go bck in to the tranny, also could just be the u-joints going out. i would inspect the small things first.)
possibly motor mounts, hope your not using solids. solids= nevermind,if you had solids,you wouldn't know you had a problem
393strokervert is offline
Old 07-18-2009, 11:51 AM
97modifiedmustangGT
well the vibration problem should be fixed by tuesday because apparently the flywheel was a 50 oz. after we pulled the engine again. i guess they didn't take the time to run the part #.
Another problem that i see him having is it seems to run hot. It doesn't have a t stat at the moment and for the short time we had it running it wanted to run hot. we had the fans on at all times (dual 12in.) and if you sit long enough it will creep its way up to 210 and i don't see it stopping there. while cruising and the fans on it stays around 195 but if you don't have the fans on while cruising it will shoot right up. I'm just thinking the water pump may be bad but what else could it be?
Old 07-18-2009, 01:14 PM
393strokervert
Default running hot
try checking your timing, retarted timing can cause it to run hot, also how old is the radiator & water pump??? is the car an ex4banger? if it is a 4cyl radiator then you definitely need one for a 5.0. if it doesn't get down to 180* or so,maybe even in the 170's with no thermostat then it sounds like either retarted timing or a bad radiator or water pump to me. hope this helps
Old 07-18-2009, 01:59 PM
97modifiedmustangGT
it has a good radiator and i'm not sure about the water pump. this 351 has only about 25k original miles but it has been sitting for a while before we finally swapped it over. we have a parts car that i know the pump was fine on so we might just end up pulling that one off. thanks for the input.
Old 07-18-2009, 04:05 PM
393strokervert
Good luck, I hope you find the problem & get it fixed easily. I feel your pain having problem after problem. been there,done that... also, good to here that you found your vibration problem, some people chase them for a long time.
mtgldr
02-03-2024 09:00 PM
4cylinderplus2
10-09-2020 07:45 PM
baddog671
07-26-2016 01:20 PM
mdj89
09-23-2015 08:49 AM
ccdguy
09-19-2015 05:20 PM
Quick Reply: need help with a vibration
