Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang > 351 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 07-27-2009, 08:16 PM   #1
philkat2007
1992 Ford Mustang
philkat2007's Avatar
Vehicle: 88 GT, 94 Cobra(sold), 97 Roush(sold), 97 M3, 92 coupe
Question 1971 351w block vs 1994 351w block??
I know if I am looking for 700+ hp then no questions asked I would go with a Dart block. However I am wanting stroker 408 with 525-575 hp with a prosystem 780cfm carb, AFR heads and so on. I have most of the parts ready waiting for a block. Should I go with the "71 block beefier 2 bolt and convert to 4 bolt or should I go with a "94 block? 71 is what I'm thinking cause I know its a stronger block. The HP ratings above will be all motor then I will have a 150 shot of NOS for the little extra ump putting the ratings around 650 hp when all said and done. In advance thanks for the help..........
philkat2007 is offline   Reply With Quote
Old 07-27-2009, 08:26 PM   #2
Liquid_02
Vehicle: 92 GT
Quote:
Originally Posted by philkat2007 View Post
I know if I am looking for 700+ hp then no questions asked I would go with a Dart block. However I am wanting stroker 408 with 525-575 hp with a prosystem 780cfm carb, AFC heads and so on. I have most of the parts ready waiting for a block. Should I go with the "71 block beefier 2 bolt and convert to 4 bolt or should I go with a "94 block? 71 is what I'm thinking cause I know its a stronger block. The HP ratings above will be all motor then I will have a 150 shot of NOS for the little extra ump putting the ratings around 650 hp when all said and done. In advance thanks for the help..........
I'm running a 408 w/ victor jr's and all that jazz, makes roughly the power you're looking at, I'm using the roller block with no troubles as of yet. If I were to go with nitrous, I'd get a better block, nitrous is a killer on anything, much harder on it than just making that power N/A.
Liquid_02 is offline   Reply With Quote
Old 07-27-2009, 08:47 PM   #3
philkat2007
1992 Ford Mustang
Good point Liquid_02. N/A I knew either would be fine but the bottle was my main concern. Do you have any other blocks you would recommend for this. As for the Dart blocks, if I spend 2800 for that then this project could be a little much for a street/strip car (meaning HP).
Old 07-27-2009, 08:53 PM   #4
Liquid_02
Vehicle: 92 GT
No I couldn't recommend a block to withstand that :\ you're probably better off going as old as you can find though, I doubt even them would much like the nitrous though, so if you want to stick with a stock casting, in your case, the older the better
Old 07-27-2009, 09:09 PM   #5
philkat2007
1992 Ford Mustang
Liquid_02 Thanks. Nice Stang you got. Your project looked like mine from day one.
Old 07-27-2009, 10:55 PM   #6
87notch408
87notch408's Avatar
Vehicle: 1987 Ford Mustang Notch
I think either block would be okay without the bottle but I would (and did) choose a roller block.
I am running mine all motor this time. I had a 175 shot on the 351 before I pulled it to stroke it. I was pretty shocked at the bearing wear with very few miles on the engine.
__________________
-Kevin
1987 Mustang Notch
408 Roller Block, Scat rotating assembly, Windsor senior heads, Lunati Voodoo cam, Victor jr intake, BBK longtubes,
C4, Transbrake with full manual reverse valvebody.
Granatelli tubular K member, A-arms, Coilovers and Strange adjustable struts.
Auburn locker rearend, Moser axles, Lakewood traction bars, Competition Engineering adjustable shocks.
4 point cage.
87notch408 is offline   Reply With Quote
Old 07-28-2009, 03:59 PM   #7
philkat2007
1992 Ford Mustang
87notch408 Thanks for the info. This calls for some major research. I may end up leaving the bottle off. If I decide differently then I may end up with just a 50 shot for the hole and getting more out of the motor like planed before. Mid 10's is my goal and can be done N/A but it will call for some good R/T and not so cheap parts.
Old 08-09-2009, 07:01 PM   #8
uedlose
1989 Ford Mustang
uedlose's Avatar
Vehicle: 89 mustang
any 351W block should go 700HP if the tune is right and it is built right. Some of the guys over at Turbo Forums are pushing the 1000 HP mark on stock W blocks. I got 2 guys I run around with one runs 9.20 150+ stock block 408 in a stang and the other made 800+ hp on his stock block but he took it apart to check it out one winter and was getting main cap walk so he moved up to a dart block his is a 383 with a 88MM turbo on it. Now it makes over 1000HP on the dart.
__________________
New low boost times 11 psi 10.91 @ 128 MPH 1.76 60ft 6.98 1/8 mile. still only a 306 CID yes its been a lot faster.
uedlose is offline   Reply With Quote
Old 08-19-2009, 11:12 PM   #9
MaroonNotchback
Vehicle: 1988 ford mustang
From personal research and experience i don't think you will have any problems with any year windsor block in less you have 1500 hp lol i would leave out the nos that **** is a killer in less you like **** breaking and spending money. good luck tho keep us posted =)
MaroonNotchback is offline   Reply With Quote
Old 08-22-2009, 04:37 AM   #10
fs308
1995 Ford Mustang
My Garage
fs308's Avatar
Vehicle: 87 piece of sh!t
you can run mid 10's NA so there is no need for the nitrous. find any block you can get your hands on and build it
__________________
Project:POS
fs308 is offline   Reply With Quote
150, 1971, 1994, 1995, 351, 351w, 408, 408w, 71, 88mm, block, mustang, roller, shot, stroke, stroker, turbo
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
