FWIW I have a 94 roller block that I have bored and stroked to a 408. Should be around 500 - 550 HP (depending on what heads I use). I have that Canton main support girdle but no valley girdle and I plan to twist it up to 7000 - 7200 RPM's.
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
__________________
-Kevin
1987 Mustang Notch
408 Roller Block, Scat rotating assembly, Windsor senior heads, Lunati Voodoo cam, Victor jr intake, BBK longtubes,
C4, Transbrake with full manual reverse valvebody.
Granatelli tubular K member, A-arms, Coilovers and Strange adjustable struts.
Auburn locker rearend, Moser axles, Lakewood traction bars, Competition Engineering adjustable shocks.
4 point cage.
My stock block 408 goes 9.80's on a 125 shot. It is a roller block no girdles top or bottom, hydraulic roller, and I'm not sure how many horsepower. Shift at 6600 rpm.
That's what I figured. So I'm trying to figure out what I want to stroke this motor out to. I realize it's not going to be hard to pull about 450 hp out of this motor. I'm thinking 393, 408, or 427. Any advantages or disadvantages to any of these?
__________________
I do ultra-sonic reverse flow injector cleaning and rebuilding, pm me if interested
Agreed. 0.060 over was just a little too much for me, and after getting the 408 kit in and looking at the bottom end, I'm glad I didn't. even with the 408 there isn't much piston left in the bore. 393's go real nice too, I wouldn't be afraid at all of putting one of them in.
you dont seriously buy into that "valley girdle" bull****... do you?
I do depending on what you are running. I have seen more than one block cracked in the lifter valley. That being said I did not put one in my engine. It is extra insurance if you are pushing the limits.
If you are going to install a roller cam you must make sure it is a retro fit roller cam. You will need to get a roller cam installation kit along with tapping the block in the lifter valley to install it. Its not a big deal, you just have to be aware of it.
CCCharleston, your car goes good! gets some good traction.
__________________
-Kevin
1987 Mustang Notch
4 point cage.
fail fail and more fail....
no machining needed, no tapping, no installation kit... link bar roller lifters and a STANDARD base circle roller cam are ALL thats needed
__________________
Siggy removed by Administration.
