Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang > 351 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 08-12-2009, 12:12 AM   #1
92hatchLX
Default Fuel system for carb conversion
I know you can't use the stock style set up for feeding a carb. I've heard of people wiring in a lower pressure electric pump inline with the stock fuel line. What are you guys using that have converted from an EFI to a carbed set up feeding a 351w based motor?
__________________
I do ultra-sonic reverse flow injector cleaning and rebuilding, pm me if interested
92hatchLX is offline   Reply With Quote
Old 08-12-2009, 03:07 AM   #2
hillbilly pony
1987 Ford Mustang
If you use the adapter that allowes you to go from the stock EFI lines to a AN Fitting you can run a braid to a LP Carb style regulator some have had luck with that. other option is Sump your tank and just slave in a LP pump to the wires at the tank. then use a carb reg..
__________________
1987 GT. 13.7:1 408 with TW "R" heads, Probe SRS Flat Tops, custom pro systems 950 carb. .671/671 comp cam. Rollerized C4 w/brake 4800 stall, Strange 31 splines w/spool. 10 point cage, Subframes, 4Cyl springs and 90/10's, 50/50's and lakewood uppers/lowers. 325/50/15's
hillbilly pony is offline   Reply With Quote
Old 08-12-2009, 03:17 AM   #3
Liquid_02
Vehicle: 92 GT
Quote:
Just do the same thing I did. Mine's EFI, but just a matter of changing my FP, or, lowering my fuel pressure since this pump is rated down to 10psi, to turn it into a carb system.
Then just run them all the way to the front. 8AN braided line, 50FT (I used less than 40FT, used my left-overs for my tranny cooler) cost me something like $150, fittings about another $75 and sump was $40. And Voila, you have an NHRA legal fuel system, and being 8AN, you'll never have to worry about running out of fuel, as long as you have a big enough fuel pump, also on top of it all, you get a sump, which is much, much better than any other method, as when you launch, the fuel goes to the rear of the tank, being in the stock location, you risk sucking up some air, leaning you out.
Considering you're fueling a 408, if my memory serves, I wouldn't use the factory lines.
Liquid_02 is offline   Reply With Quote
Old 08-12-2009, 07:15 AM   #4
87notch408
87notch408's Avatar
Vehicle: 1987 Ford Mustang Notch
Liquid 02, Where is your second fuel line out of the sump going? I can see one goes into the fuel pump and the other one looks like it runs to the top of the fuel pump.
__________________
-Kevin
1987 Mustang Notch
408 Roller Block, Scat rotating assembly, Windsor senior heads, Lunati Voodoo cam, Victor jr intake, BBK longtubes,
C4, Transbrake with full manual reverse valvebody.
Granatelli tubular K member, A-arms, Coilovers and Strange adjustable struts.
Auburn locker rearend, Moser axles, Lakewood traction bars, Competition Engineering adjustable shocks.
4 point cage.
87notch408 is offline   Reply With Quote
Old 08-12-2009, 09:40 AM   #5
Liquid_02
Vehicle: 92 GT
Quote:
That's the return line, regulator to tank
Old 08-12-2009, 05:33 PM   #6
wagontrain
1978 Ford Fairmont
wagontrain's Avatar
Vehicle: 78 Ford Fairmont
The return line should be above the fuel level as to not have pressure in that line.
__________________
Worlds fastest 357 c.i.d.,With one Holley Dominator,One nitrous system,Turbo 400,Nine inch,All steel and glass,except hood,95% stock floor,Almost all stock interior,1983 Crimson Cat,Mercury Capri RS in my garage.(8.31 166)Under Reconstruction!
1978 Ford Fairmont Stationwagon,351 Windsor,Turbo-350,8.8 31 spline axles,steel spool,T/A cover,4.30 gear,MM Adj.Lowers,Baseline Pro-launch#2,Track locator,Anti-roll bar,UPR K-member,A-arms,Coilover kit,Manual rack,Bumpsteer kit.470,440@wheel
wagontrain is offline   Reply With Quote
Old 08-12-2009, 07:59 PM   #7
Liquid_02
Vehicle: 92 GT
Quote:
Return line will always have pressure. Doesn't matter where or how you mount it, aside from that you think a liquid's going to stop 40psi of pressure, or 7 psi in a carbed application? As as long as the pressure in your return line is not equal to that of your desired pressure, it won't have any effect on it. Will have absolutely no bearing on how the fuel returns to the tank. Usually you mount it away from the pressure line, so it can't interfere with the suction of the pump, that't all. I made a baffle to stop the return from interfering.
Old 08-13-2009, 09:15 AM   #8
87notch408
87notch408's Avatar
Thats what I thought it was. Your fuel system looks a lot like mine except I used a Aeromotive 2-1 so I have two feeds from my sump into my fuel filter then from my fuel filter to my Holley pump. I have my return coming into the top of my fuel cell.
__________________
-Kevin
1987 Mustang Notch
4 point cage.
Old 08-17-2009, 05:20 PM   #9
wagontrain
1978 Ford Fairmont
wagontrain's Avatar
That is the typical way of doing it,but I guess there are more ways then one to skin a cat.
__________________
Old 08-17-2009, 11:23 PM   #10
Liquid_02
Vehicle: 92 GT
Fair enough, mine being injected, fuel system isn't really much a problem for me, just a matter of upping the PSI if it tries to starve itself in the top. I was more worried about having too much fuel for the return than too little in my case, as my regulator has a 6AN outlet that I converted to an 8AN, that way if it was too small, it was just the matter of replacing the regulator with one with an 8AN fitting, but all worked out for me. This Mallory pump is a POS though, I see why they're going out of buisiness, only reason I bought it, it was about $100 less than any other pump, and now I see why.
46, 50, 92, carb, carbed, carburated, conversion, fuel, make, mustang, return, set, setup, supercharged, system
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
