Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang > 351 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-05-2009, 02:03 PM   #1
92hatchLX
Default TF twisted wedge heads breathe enough?
I found a set of rebuilt trickflow twisted wedge heads with the 2.02 and 1.60 ferrea valves that have been milled down to 58cc for a great price and I was wondering if these would breathe enough for the 408w stroker that I'm building? My goal is around 450 rwhp.
__________________
I do ultra-sonic reverse flow injector cleaning and rebuilding, pm me if interested
92hatchLX is offline   Reply With Quote
Old 09-05-2009, 04:42 PM   #2
wildcobrar
Vehicle: 1990 Mustang Hatch LX
What TRS head are they? Meaning part number so you can figure out intake runner size and so on. On a 408 inch engine you will need a total volume of 88 cc to come in at 10.5 to 1 compression for pump gas. 58 for the heads about 6 cc valve reliefs and ring lands and about 9 cc for the head gasket. You will need about a 15 cc dish in the piston. With a flat top pistonand those heads you will be about 12.5 to 1 compression.
Joe
__________________
Always in search of faster ET.
]IMAGE][/IMG]
wildcobrar is offline   Reply With Quote
Old 09-05-2009, 04:44 PM   #3
wildcobrar
One other thing. You will need to make about 565 HP at the flywheel to get into 450 at the wheels. You will need a fairly serious cylinder head for the to get there N/A.
Joe
__________________
]IMAGE][/IMG]
Old 09-06-2009, 01:04 AM   #4
92hatchLX
So I should probably just stick with my original plan of AFR 205's then. These heads would probably work great on my blown set up that I'm running right now, probably not soo well on a 408
__________________
Old 09-06-2009, 10:36 AM   #5
wildcobrar
Quote:
Forced induction changes everything. Bore size will have less issue with valve size and placement with forced induction.
Care to give detail to your forced induction set up with your current heads?
Joe
__________________
]IMAGE][/IMG]
Old 09-06-2009, 10:59 AM   #6
92hatchLX
Well this motor will be yanked soon enough and sold. I'm not buying the heads. But my set up is really nothing special, TFS1 cam, TFS street heat upper and lower, ARP head studs, fel-pro high performance head gaskets, E7 iron heads with massaged exhaust ports (done by me), Novi 1000 pushing 6 psi. All the bolt ons, exhaust, etc.
__________________
Old 09-06-2009, 11:32 AM   #7
wildcobrar
What is your game plan with the AFR 205 heads?
Joe
__________________
]IMAGE][/IMG]
Old 09-06-2009, 09:55 PM   #8
92hatchLX
I did some more reading today and others with big inch windsors are running 225's. I'm haven't thought about the heads much, also keeping in mind the TF-R heads or some big high ports. I'm trying to get over the cost of the shortblock that I'm ordering right now. I guess I'll come to selecting a head after I get the shortblock. My goal is a tad over 500 flywheel horsepower, running a non forged CHP 408 kit in a 94+ block. I've got an 89 block laying around but I figured that between machining that block and the stroker kit, and linkbar lifters. I'd be better off having Jim at Ford Strokers build me a short block in a roller block. Hell, I'm saving $400 just by using a 94+ block and he stands behind his work.
__________________
ferrea, find, flow, ford, head, heads, modular, number, part, rebuild, sale, trick, twisted, valves, wedge
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
