Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang > 351 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-10-2009, 12:44 AM   #11
nissan owner
Vehicle: 1984 Ford Mustang
Quote:
Originally Posted by AdderMk2 View Post
185 is a bit small for a 351. Most guys who street their 347's will run a 185. I opted to run a 192cc head that had some light port work. They do VERY well on my car
If i had the money to go with the AFR205's id have them... but my Canfields were $1000 cheaper
http://www.canfieldheads.com/sbf_cncc.html
Are you talking about these? You think they can outperformed the AFR's 185cc?
I figured that with that mild cam that I have and AFR's 185's should get me a good time N/A...maybe mid 12's or high 12's...then just shoot a 150, to see what I end up with.
nissan owner is offline   Reply With Quote
Old 09-10-2009, 04:42 PM   #12
jfritts
1969 Ford Mustang
jfritts's Avatar
Vehicle: 1969 Ford Mustang
i would step up to the 205cc heads. be sure to match combustion chamber with the compression ratio you want.
jfritts is offline   Reply With Quote
Old 09-12-2009, 02:32 PM   #13
wagontrain
1978 Ford Fairmont
wagontrain's Avatar
Vehicle: 78 Ford Fairmont
I have Canfield 205s on my car, they make good power, but all Canfields crack at some point in there life,spend what little extra money it is and get some AFR 205 or the 225 and run a cam in the high 240's and low 250's duration at .050 and what ever lift comes with that and you will be happy.The bigger(reasonably) the head the less cam you have to run to make power.\/\/\/
__________________
Worlds fastest 357 c.i.d.,With one Holley Dominator,One nitrous system,Turbo 400,Nine inch,All steel and glass,except hood,95% stock floor,Almost all stock interior,1983 Crimson Cat,Mercury Capri RS in my garage.(8.31 166)Under Reconstruction!
1978 Ford Fairmont Stationwagon,351 Windsor,Turbo-350,8.8 31 spline axles,steel spool,T/A cover,4.30 gear,MM Adj.Lowers,Baseline Pro-launch#2,Track locator,Anti-roll bar,UPR K-member,A-arms,Coilover kit,Manual rack,Bumpsteer kit.470,440@wheel
wagontrain is offline   Reply With Quote
Old 09-12-2009, 08:16 PM   #14
nissan owner
Do you guys think 215cc Racing Head service heads would be a good alternative, or maybe some 210cc Edlebrock Victor Jr. Heads...Or should I just stick with the 185cc and go with stuff that is proven day in and day out?
Edit just saw the flow chart on the vic. jr's they are the same thing as the 185cc i would just stick to AFR if it came to that...So its RHS vs. AFR right now....
Old 09-12-2009, 08:18 PM   #15
nissan owner
Quote:
I saw your sig, can you give full mod list of your car and possible track times to see where I could stand compare to your car?
Old 09-13-2009, 09:34 AM   #16
wagontrain
1978 Ford Fairmont
wagontrain's Avatar
big horsepower stuff haha
__________________
Old 09-13-2009, 12:57 PM   #17
nissan owner
^^^Thanks
Old 09-13-2009, 12:59 PM   #18
nissan owner
So RHS vs. AFR???
The RHS 215cc are 200 bucks cheaper, than the 185cc AFR...Also they flow better than the AFR's according to the flow charts...But does anyone have any reviews on RHS
Old 09-13-2009, 02:25 PM   #19
AdderMk2
MF Attention Whore
AdderMk2's Avatar
Vehicle: 1994 Ford Mustang Cobra
Send a message via AIM to AdderMk2
Quote:
Originally Posted by nissan owner View Post
So RHS vs. AFR???
do a search under my name for threads I created.. go back about... a year and a half
*edit*
http://mustangforums.com/forum/5-0-m...rhs-heads.html
__________________
Siggy removed by Administration.
The Man is trying to oppress me...
AdderMk2 is offline   Reply With Quote
Old 09-14-2009, 08:12 PM   #20
nissan owner
F it I am just going to pull the trigger...I'll just post a thread pretty soon with my build, dyno numbers, and track times for other newbies such of myself to be aware of what set ups are around.
185, 1981, 205s, 347, 351, 351w, afr, build, builds, ford, heads, size, valve, wafr, windsor
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
