Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang > 351 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-14-2009, 08:14 PM   #21
jfritts
1969 Ford Mustang
jfritts's Avatar
Vehicle: 1969 Ford Mustang
oh the stress of picking expensive parts that your not sure of. well good luck on it cant wait to see finished product
jfritts is offline   Reply With Quote
Old 09-14-2009, 08:19 PM   #22
nissan owner
Vehicle: 1984 Ford Mustang
By the way 185cc AFR will be my choice.
nissan owner is offline   Reply With Quote
Old 09-15-2009, 12:22 AM   #23
wildcobrar
Vehicle: 1990 Mustang Hatch LX
Quote:
Ummm, I think a few people need to learn more about cylinder heads before making choices and recommendations.
I would not put a 180/185 anything on a 351 inch engine before looking at cost vs performance. Secondly, everyone finds themselves wanting more performance down the road. So I would also open my choices to heads I can grow into if for example I decided to add cubic inches into the program by stroking the 351.
Joe
__________________
Always in search of faster ET.
]IMAGE][/IMG]
wildcobrar is offline   Reply With Quote
Old 09-15-2009, 08:31 AM   #24
AdderMk2
MF Attention Whore
AdderMk2's Avatar
Vehicle: 1994 Ford Mustang Cobra
Send a message via AIM to AdderMk2
do you ****ing pay attention at all???
Quote:
Originally Posted by AdderMk2 View Post
185 is a bit small for a 351. Most guys who street their 347's will run a 185. I opted to run a 192cc head that had some light port work. They do VERY well on my car
If i had the money to go with the AFR205's id have them... but my Canfields were $1000 cheaper
__________________
Siggy removed by Administration.
The Man is trying to oppress me...
AdderMk2 is offline   Reply With Quote
Old 09-15-2009, 10:13 AM   #25
nissan owner
Based of flow charts, 195cc Canfields vs 185cc AFR's...the AFR's flow just as good as the canfields, can you explain that? Also Canfields and AFR's are the same price, or can you show me where I can get canfields 1k cheaper, because AFR's are only 1400?
Old 09-15-2009, 11:52 AM   #26
wildcobrar
You do not understand. Bore size also has an effect on flow due to valve placement. Look at AFR 205 Heads. AFR flows them on a 4.125 inch bore. They do so because ona 4.030 bore they drop in flow because of "valve shrouding" at the cylinder wall. There are other heads(that move the valve arrangement(which changes port length, cross section, and how the engine itself see's air/fuel entering the engine) The move in valve arrangement changes short side entry to the bowl, it changes valve shrouding, and changes the way a cylinder fills during the intake stroke.
Guys who understand this get the most value for their $$$$$$$$$$$$$ and they are usually the one that hands you your A$$ at the track or on the street.
Nuff said,
Joe
__________________
]IMAGE][/IMG]
Old 09-15-2009, 03:42 PM   #27
AdderMk2
MF Attention Whore
AdderMk2's Avatar
first off, AFR205s are $1700... i bought my canfields for 650.. its not my problem that you dont know how to shop for parts.
and i strongly suggest that you stop looking at manufacturers flow tables... those things are so skewed its not even funny.
there are a few guys here with AFR185s on thier 347s and making around 340-360hp. one guy has TFS heads making 380+, and my car, with the canfields is making just shy of 400
take it FWIW but when you arent making the power you want. im merely gonna say "i told you so"
__________________
Old 09-15-2009, 09:49 PM   #28
mjr46
Sheriff/Mr. Ballbreaker
mjr46's Avatar
Vehicle: 85 mustang
I wouldn't attibute their lower hp numbers soley due to heads they have, I gaurantee my afr 185 headed 347 is putting out way more than 360 expecially now with the recent combo reconfigure, but then again et is all that matters to me
__________________
Quote:
Originally Posted by dudeboy View Post
Be polite and cordial when you talk to them, as pissing off the guys that can help you is seldom a good idea.
mjr46 is offline   Reply With Quote
Old 09-15-2009, 11:21 PM   #29
irish1
Vehicle: 1981 Ford Fairmont Futura
There are a couple things I would like to point out:
1 If you get impatient and select the wrong parts and do not like the way your car runs, then you need to do it again. Doing it 2X costs dearly, you would have been better off buying a really good head to start with. Do it once, the right way.
2 If you are super confused about it, pick up the phone, call someone who knows even if they charge you a little. Nobody who hands out advice for free on the internet is going to help you take care of things if they gave you bad advice.
Matt
irish1 is offline   Reply With Quote
Old 09-16-2009, 08:50 AM   #30
wildcobrar
Quote:
Just curious, what is the combo? compression ratio...............? 185 AFR heads, 347, camshaft..................? Intake................? Headers...............? efi or carb...............? rear gear................? Weight of car with driver................? MPH in 1/4........................? ET in 1/4....................?
I have used AFR 185 heads on quite a few builds. Just curious about your ride. I will share my set up as well if you wish,
Joe
__________________
]IMAGE][/IMG]
185, 1981, 205s, 347, 351, 351w, afr, build, builds, ford, heads, size, valve, wafr, windsor
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
