Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang > 351 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-08-2009, 09:12 PM   #1
nissan owner
Vehicle: 1984 Ford Mustang
Default 351W Build inputs...
Hi my name is Ray, I am fairly new to the Mustang world...So I need some help, and would really appreciate anyones input. I currently have a 84 Mustang GT and I am looking to drop a 351W. I currently have pretty much the short block assembled, which consist of the key components; Lunati 61004LK cam, Keith Black pistons (hypereutectic flat) I belive its 10:8:1 with 60cc head, stock crank and rods. Also it is bored out 60 over. So thats the background with that.
Okay I am looking for 400whp N/A (Or to get as close as possible) so for the top portion I was looking at possibly going with these heads, which I want to know if any of you have used them, POWERHOUSE SB Ford Aluminum Heads - 60cc/210cc As Cast Ports/Chambers https://shop.enginekits.com/osb/itemdetails.cfm?ID=2933, a good intake manifold as well as a 750cfm carb...
Do you guys see it possible? This will be through a C4 and 3.73 gears. Looking for a track car and don't really care for drivability. Any input would be great. Keeping in mind the short block is already assembled. So let me know thanks
nissan owner is offline   Reply With Quote
Old 09-08-2009, 11:10 PM   #2
AdderMk2
MF Attention Whore
AdderMk2's Avatar
Vehicle: 1994 Ford Mustang Cobra
Send a message via AIM to AdderMk2
325hp here you come (if your lucky)
__________________
Siggy removed by Administration.
The Man is trying to oppress me...
AdderMk2 is offline   Reply With Quote
Old 09-08-2009, 11:24 PM   #3
nissan owner
Quote:
Really wow...I figured more...What do you think is holding me back?
Old 09-08-2009, 11:27 PM   #4
AdderMk2
MF Attention Whore
AdderMk2's Avatar
cam selection, those craptastic heads
a bigger carb wouldnt hurt either
__________________
Old 09-08-2009, 11:30 PM   #5
nissan owner
What type of heads would you recommend?
Old 09-08-2009, 11:54 PM   #6
AdderMk2
MF Attention Whore
AdderMk2's Avatar
TFS fast as cast, AFR, Canfield, TEA
something of the sort
__________________
Old 09-09-2009, 12:10 AM   #7
nissan owner
Any links? of inexpensive heads?
Old 09-09-2009, 03:56 PM   #8
jfritts
1969 Ford Mustang
jfritts's Avatar
Vehicle: 1969 Ford Mustang
if you want good heads look at paying 1500-2500. heres the ones i am using. combustion chamber is a little bit bigger than what u were using http://www.summitracing.com/parts/TFS-51700012-C01/
jfritts is offline   Reply With Quote
Old 09-09-2009, 04:55 PM   #9
nissan owner
I was looking to get the AFR 185cc 58 combustion chamber would that meet my needs? or should I step up to a 205cc?
Old 09-09-2009, 06:56 PM   #10
AdderMk2
MF Attention Whore
AdderMk2's Avatar
185 is a bit small for a 351. Most guys who street their 347's will run a 185. I opted to run a 192cc head that had some light port work. They do VERY well on my car
If i had the money to go with the AFR205's id have them... but my Canfields were $1000 cheaper
__________________
185, 1981, 205s, 347, 351, 351w, afr, build, builds, ford, heads, size, valve, wafr, windsor
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
