I have a 351 in my 95 and use a Saleen hood. I also read in one of the Mustang mags that you could change out the motor mounts to lower the motor a bit and fit under the stock hood; of course it would also depend on the intake you are going with.
__________________
1995 Saleen S351 Replica. 351 Sportsman block, Forged Bottom end, Trick Flow upper/lwer intake, Aeromotive A1000 fuel system + adj fuel press reg. Vortech V2 Strim 8lbs boost, Andersen power pipe, Maximum Motor sports UCA & LCA, 3:73s w/ Girdle, Canton 7Qt oil pan, 50 lb injectors, Fluidyne radiator, genuine Saleen body kit, S351 wing & heat extractro hood, Nitto NT555, Aluminum fuel door, Cobra brakes F&R, T56 transmission, aluminum DS, BBK lowering springs, Steeda CC plates, Optima Battery.
