Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang > 351 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-17-2009, 12:51 PM   #1
kshmny925
Vehicle: 1995, Ford, Mustang GT
Default 351w stock rod strenght
hi, i getting ready to do a 351w swap into my 95 gt and i want to keep the budget down where i can, but i dont want to cut too many corners (contradicting i know) and i know i can do a 393 with a 4.030" bore, stock 5.956" rods, and a 3.85" crank, BUT how much power can the stock rods handle???
im looking around 450-500 at the crank. with the setup im going to run.
thanks in advance
kshmny925 is offline   Reply With Quote
Old 09-17-2009, 08:10 PM   #2
wildcobrar
Vehicle: 1990 Mustang Hatch LX
thanks in advance
Truck rods are stronger than car rods. You need to change up to ARP rod bolts and resize and use 351W truck rods. They will handle 450 to 500 HP but do not go power adder and do not try to make peak power past 6000 rpm.
They will run fine if you stay within those suggestions.
Joe
__________________
Always in search of faster ET.
]IMAGE][/IMG]
wildcobrar is offline   Reply With Quote
Old 09-18-2009, 09:45 AM   #3
kshmny925
Joe
thanks again, i guess im just going to have to buy arms as well just to be on the safe side.
Old 09-20-2009, 06:05 PM   #4
uedlose
1989 Ford Mustang
uedlose's Avatar
Vehicle: 89 mustang
if you have to get truck rods and then have them re-sized and pay for good rod bolts you might be better off getting a Probe budget I beam instead they are strong then truck rods. But it is all in what you can afford that is for sure
__________________
New low boost times 11 psi 10.91 @ 128 MPH 1.76 60ft 6.98 1/8 mile. still only a 306 CID yes its been a lot faster.
uedlose is offline   Reply With Quote
351, 351w, 393, 500, crank, crankshaft, ford, good, handle, horsepower, hp, rod, rods, stock, truck
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
